Page 2 of 4
Re: New to Chieftain
Posted: Tue Jul 09, 2024 11:35 pm
Looking at the spec sheet, they're only rated for 25A maximum continuous discharge current, which is pretty low for a battery in that class.
I don't know the usual current draw on Chieftain but I've seen 40A - 50A with the King Tiger and the JagdTiger driving on grass, and that's with stock tracks, not steel ones.
Posted: Wed Jul 10, 2024 10:56 am
by Steve Cope
Hi
Thank you for the information, I was going by a picture that I was sent of the Panther G electronics layout, they had these installed, at the moment they are only £99.00 on Amazon. I thought this might be a good time to change as. I could continue with the same batteries as I have in my Panther, Yuasa ENG22-12 as recommended for the panther by Armortek.
Is their anyone that you can recommend to talk to about the chieftain setup or just post a general enquiry?
Many thanks
Posted: Wed Jul 10, 2024 11:40 am
Have messaged a couple of people who have running Chieftains. Will let you know what they come back with.
A friend has just bought a set of those Eco-Worthy batteries and they state on them that the continuous current is 30A and the peak is 75A, so better than I thought.
Posted: Wed Jul 10, 2024 12:15 pm
by Steve Cope
Cheers Adrian
Posted: Wed Jul 10, 2024 12:56 pm
1st response:
"I'm using gel batteries 12V 24Ah Yuasa part no NP24-12I. Been in use 3yrs now, get about 90 to 120mins running time pending on smokers."
Adrian
Posted: Wed Jul 10, 2024 7:15 pm
by Mark Russell
Second response: LSLC22-12. 12 volt 22Ah Lucas sealed lead acid. I reckon 60 to 90 minutes if you are lucky with constant running around with no smokers turned on. This was my result from the Armortek open day this year, and I was constantly running up and down the ramp obstacles.
Thanks,
Posted: Sun Jul 14, 2024 3:07 pm
by Steve Cope
Hi
I have managed to get a good deal on 2 X LifePO4 Batteries 12v - 30Ah - discharge 100A, plus I brought a charger off Amazon £21 so hopefully this will be a lighter combination.
Posted: Sun Jul 14, 2024 3:20 pm
by Steve Cope
Update, Chieftain.
I was able to get to England on Friday and visited Armortek, met up with Kian, had a good chat and left with my Chieftain, Armortek XX (prototype), this will definatly be a challenge, as you probably know it is assembled but not complete or painted, so my idea will be over time disassemble and paint, I am hopefully going to do the Berlin paint scheme, well I'm not, the wife will do it
I will post some pictures of how it looks at the moment, when I work out how to post them on the Forum
Posted: Mon Jul 15, 2024 12:23 am
Posted: Sat Jul 20, 2024 4:15 pm
by Peter Brown
Steve Cope wrote: ↑Sun Jul 14, 2024 3:07 pm
Hi
Hi Steve, was it the ECO-WORTHY or another manufacture that you went with in the end?
All the best
Peter
Posted: Sun Jul 21, 2024 11:42 am
by Steve Cope
Hi Peter,
I did not go with the ECO-WORTHY
The Manufacturer I went with is LiitoKala, it has a better discharge rating
Posted: Sun Jul 21, 2024 12:22 pm
by Steve Cope
As prevously posted, I am now the proud owner of Chieftain MBT Mk V Prototype XX,
Takes up most of the car, might have to look at a bigger car, that is another bit of negotiation with management
Posted: Sun Jul 21, 2024 12:24 pm
by Steve Cope
Posted: Mon Jul 22, 2024 9:04 am
by John Clarke
Looks like you've got a decent build there Steve
Good to see you got it home safely, looking forward to seeing what you do with it.
Does it have double X stamped inside?
I was wondering what other goodies Armortek gave you with it?
Posted: Mon Jul 22, 2024 10:58 am
by Steve Cope
Hi John
I must admit I have my work cut out, there are bits missing and I need to try and work out how to fix an issue with the turret bearing not lining up with the hull, so it is not fixed, there seems to be a 5mm gap between the front of the hull and the rear so none of the retaining holes line up, plus I will be stripping it down so that it can be painted as there is a lot of rust showing itself.
I will post pictures of my progress and I will post a picture of the issue I have got with none of the retaining position holes lining up, hopefully the communty will have ideas how to resolve
Yes the XX is stamped on the inside.
Sorry to say no goodies from Armortek
Have you built the Chieftain?
