Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
Chieftain Phil, maybe yours! 8) note the new Cura organic sacrificial support structures .....it's different.
Been liked: 1731 times
Chieftain?. Did I hear Chieftain? Looking forward to that.
Though I'm still being enthralled with the Centurions.
Hoping you'll be doing a slip ring mod on the turret so I can compare with my little project this spring. 8)
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Phil,
Chieftain? ooh, you tease! :lol:
That's all the road wheels done, now onto the final drive units.
I Just love the organic support structure, the deep sea vent tubes snake around to support over hangs and bolt detail from far away!
This part is one of the flexi exhaust pipes that connects the large smoke reducing box to the exhaust headers. That desmoking box didn't work by the way!
I want the cut to be one continuous removal of material, so the rotary table needs to earn its keep.
That's all the road wheels done.
Chieftain rear engine bay parts are coming along nicely.
Charles A Stewart
Has liked: 485 times
Been liked: 898 times
Post by Charles A Stewart »
Hi Phil.
Don't get me wrong, but I see chieftain parts appearing on a Cent thread, am I correct?
The Cent make over is really good and I do like following these posts.
With all due respect to participants and without trying to hijack this lead: It is the 3d printing that gets my attention. are you open for commissions?
Cheers all
Charles
So I don't upset anyone email me Charles Exploration20@outlook.com I'm just saving ink by combining the very similar vehicles components which I feel may be interesting to folk, we intend to fit a full engine compartment to the Cent.
Been liked: 1632 times
your getting too good Phil, regards simon.
Machining the first of the final drive cases.
I've been experimenting with the fixings.Functional dome heads this side blended in to look like the castings.
The cast ribs will be tricky.
Lots of blending to do to get that skinny look.
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
Phil,
your build report is always so inspiring and detailed.
It is a great pleasure to follow your excellent build.
Best wishes
Oliver
It's Grim Up North
I wasn't really looking forward to this tricky job but I'm very pleased with the outcome.
I think the pictures tell the story.
The ali stock is an interference fit and is pressed in and bonded.
Couldn't resist some NATO green paint.
It's far to clean for a casting so will need some more work.
Last edited by Phil Woollard on Sun Mar 27, 2022 12:50 pm, edited 2 times in total.
Derek Attree
Has liked: 218 times
Been liked: 178 times
Post by Derek Attree »
Hi Phil
Just one word.
WOW.
Phil Dawe
Post by Phil Dawe »
Looking good Phil. I am glad the procedure worked as planned! :D
A couple of pics of the just about done off side final drive inner casting, maybe a little more fetling.
That inner final drive lump is now bolted in place for good.....I hope.
Maybe a little more surface texture to the top portion but I can do that the just before the final top coat goes on.
I've reduced the strengthening wings profiles down as far as I dare to look more like the real thing did.
Helderluiss
Has liked: 5 times
Been liked: 169 times
Post by Helderluiss »
Amazing attention to details :shock: congrats
A productive 4 hours spent this afternoon on the nr side final driver inner piece.
There's not much room for the workpiece clamp, in fact it needs moving from each side as you go.
It's nice to see the hole positions appearing in the correct place as the material is removed, you know you have the radius calculations correct.
There's is tons of material to play with.
