Page 10 of 12
Re: Armorpax's Armortek UC - No.18
Posted: Sat Jan 08, 2022 6:13 pm
by Derek Attree
Hi Dave
Happy new year
I was wondering if you ever got around to paintng your unversal carrier? If so any chance of some photos.
I am finally going to start my build in the next monh or so.
Posted: Sat Jan 08, 2022 10:48 pm
by Dave Dibb (Armorpax)
Hi Derek,
Happy New Year to you too.
Nope, its rusting quietly in the workshop at the moment. I also have the Pheasant in basecoat that needs finishing. I have actually done very little model making over the holiday as needed a break more than I had realised
Dave
Posted: Sat Jun 04, 2022 10:12 pm
Hi All,
Spotted a Carrier at the Overlord show today and liked the way the cover had been stowed. Found a gas cape that was the perfect thickness and with a waxy surface was just what I wanted. Its now cut up into sections and I have quickly test fitted. It will have to come off again as need to get this thing painted soon.
Dave
Posted: Sun Jun 05, 2022 7:57 am
by Phil Woollard
Very nice detail, do you have anymore photos of that carrier you can share Dave?
Posted: Sun Jun 05, 2022 10:16 am
Hi Phil,
I only took these 3 and a couple in the front. I'll email them over in a bit.
Dave
Posted: Sun Jun 05, 2022 6:24 pm
Hi All,
Managed to get a coat of primer on most of the Carrier before the heavens opened. Can't have Phil getting all the glory
Dave
Posted: Thu Jun 09, 2022 8:53 pm
Hi All,
Dummy diff housing to go over the ends of the 2 motors. This is not scale as the motors are way bigger dia than the original diff. The idea is it will sit over the gap between the two motors and at least give the impression of a diff.
Dave
Posted: Thu Jun 09, 2022 8:54 pm
Thanks again to Mr Harris whos' guidance has sorted the sound issue.
Posted: Thu Jun 09, 2022 8:56 pm
Hi All,
Enough gaps in the drizzle tonight to finish the priming. Little filler needed under the rifles then I can start base coating.
Dave
Posted: Thu Jun 09, 2022 10:48 pm
by Robert E Morey
Amazing amount of detail in this model - just fantastic. Great work Dave!
Posted: Fri Jun 10, 2022 11:59 pm
Hi All,
Motor cover cast and added.
Dave
Posted: Sat Jun 11, 2022 12:01 am
Hi All,
Base coating well under way.
Dave
Posted: Sat Jun 11, 2022 5:30 am
by Phil Woollard
Beautiful selection of parts Dave which make for a spectacular highly detailed model, shame about those two motors that ruin the look of the rear, you can't hide them. I won't shout to loud as I may have to go down the same route but only as a last resort.
Posted: Sat Jun 11, 2022 9:53 am
Hi Phil,
Opposed to the need to remove figures and loads of detail if I had to repair or adjust the brakes the twin motor set was a bit of a no brainer for me. As you can see from the 1:1 and rear view of the model its not much of a trade off
Certainly one I can live with. Visually I didn't have the bottom of the diff case with the original system either.
Dave
Posted: Sat Jun 11, 2022 9:55 am
Hi All,
Gauges Gloss coated and the box refitted. Ready for Stencils.
Dave
