sdkfz 7 build log.
- Been liked: 1661 times
Re: sdkfz 7 build log.
Thanks Chris, i do get carried away when it's paint time, on this build you have to do the inside and outside, it's all so visible, regards simon.
Hi All, Both sets of wheels are painted, just the centre's to work on, painted the grill to get some idea of scheme and look, plus made a start on the floor, this last building session has been about colour's and where to start, seasons greeting's to all the Armortek builder's, best wishes simon.
- Has liked: 2267 times
- Been liked: 7152 times
Simon you have an excellent eye for colour, what works, and so your weathering looks very convincing indeed!
Regards Phil
Regards Phil
- Has liked: 189 times
- Been liked: 712 times
Excellent - I want my elefant to look similar ...have to build it first tho.
season's greeting's Dave and Phil, Painting alway's put's the icing on the cake, i Have been working on the Matata Drive Sprocket's, adding the round foot step was a little awkward, not sure if this was a fitted out in the field mod on the real vehicle, or a standard production fitment, finding the correct checker plate pattern is near impossible, all for now regards simon.
- mark j. radick
- Has liked: 393 times
- Been liked: 538 times
- Has liked: 132 times
- Been liked: 784 times
Simon,
You are the master of making the brand new look old and worn. Superb!
- Heiko Sattler
- Been liked: 535 times
- Has liked: 294 times
- Been liked: 641 times
I'm reading every post of this awesome building blog.
Its best quality.
Like to see it in real on a meeting
Its best quality.
Thank you fellow builder's, The Positive Feedback is appreciated, The Wheels and centre caps are finally fitted on this side, i reshaped the caps and added the grease nipple's to as close i could make them using the kit part's, it's always a balancing act between R.C. and Shelf queen, i will add a bit more weathering to the wheels once on the home strait, now around to the other side, all the best simon.
- Has liked: 777 times
- Been liked: 1745 times
- Heiko Sattler
Thank's Men for your input, i Have finished fitting the tool's to the center section of seat's and applied some weathering to those hard to reach area's before they are permanently fitted, Painting the model in components make's it easier than doing it afterwards on this vehicle, all for now, regards simon.
A slight diversion on to the front wheels, to keep away from the main body and have a bit more thinking time on how to over come the next phase of fitting motion packs and front floors, regards simon.
Hi Simon
Front wheels look great ....hopefully I have a set coming at some point.
