John's Late Tiger 1
- Has liked: 6 times
- Been liked: 194 times
Re: John's Late Tiger 1
Hi John,
Impressing brass/soldering work!
Well done.
One tiny thing
The rear mud guards weren’t mirrored.
The square holes had the same layout on RHS and LHS, sorry...
Well done.
One tiny thing
It´s all in the details!
- Has liked: 5 times
- Been liked: 624 times
Thanks for that Kent. I was so careful not to make them the same as I almost did. I can cut that section out and solder in another.Not finished yet as I also need to cut away a small section on each side and try making the locking tabs. Also need to make the hull hinges.
Now fixed. Thanks for noticing. I came across this before but forgot.
- Been liked: 429 times
- Been liked: 1632 times
there's some nice workmanship on this build john, good to follow. regards simon manning.
Thanks Dale and Simon. Trying to pick up things from you guys.
Cutouts adjusted.
Last edited by John Fitzsimons on Tue Jan 31, 2012 9:03 pm, edited 1 time in total.
- Been liked: 177 times
Hi John
Excellent work! Cupola looks great and so do your mud flaps.
Keep up the good work!
- Been liked: 15 times
Hello John
Wow its looking good. Phew that was close where will we be without you Kent. Thanks for that.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Got them fitted now and also side fenders. Cannot find charger for camera battery at present so photos will follow soon. I mentioned before about screw fittings for side fenders and got a few suggestions. In the end I went with Rich's solution of drilling out standoffs and fitting 1/8 tubes which were then tapped for 3-48 screws. Worked well. Thanks Rich.
Rear mud flaps and side fenders fitted.
Last edited by John Fitzsimons on Wed Oct 12, 2011 10:33 pm, edited 1 time in total.
Thanks Rocky, First picture was a lucky shot. Just noticed the TV image after posting.
Here are some parts for turret interior.
I will need to source some clasps for the lids. Also get some decals printed.
Looking real good John! Nice job on the boxes.
best regards
best regards
