Page 86 of 95
Posted: Sun Jun 14, 2020 12:30 pm
by Phil Woollard
Thanks for the info, I think the warco wm 180 with dro would do the job, why is it that the model you want is out of stock?
That's the biggest stencil I have in stock but have just ordered 50mm and 60mm sets, they are expensive for what they are mind. 8)
Posted: Sun Jun 14, 2020 1:13 pm
by Derek Attree
Hi Phil
I have the Warco 250v with dro and it's a great machine over 2 years.
I have just had a WM 16vs milling machine with dro delivered as well and again it's great.
Hope this helps
Posted: Sun Jun 14, 2020 2:29 pm
by Phil Woollard
Derek that gives me confidence to buy knowing that you guys are happy with the make and models that you have chosen. 8)
Posted: Sun Jun 14, 2020 3:51 pm
by Stephen White
Phil, good advice I was given was choose your lathe and then buy one size bigger. Looks as though Warco have the 240B in stock and it's not that much more, certainly cheaper than the Sealey job:
https://www.warco.co.uk/metal-lathes/30 ... lathe.html
And no, I don't have shares in Warco or any commercial connection, much to the pity.
Posted: Sun Jun 14, 2020 4:30 pm
by Phil Woollard
That's got the bigger Chuck to, I've sent them a question regarding fitting dro to that model. 8)
Posted: Sun Jun 14, 2020 6:00 pm
by Jeffrey Goff
Hi Phil, I have had the Warco 240 for over 10 years, only problem was to replace the carbon brushes in the motor, that’s the only time it let me down, it come with its own tool kit and change wheels
Regards Jeff
Posted: Mon Jun 15, 2020 5:43 pm
by Phil Woollard
I've had a busy but enjoyable day weathering the Chieftain . 8)
Posted: Tue Jun 16, 2020 1:24 am
by Robert E Morey
Phil,
Just stunning on the detail and painting. I like how the tape peeled some of the paint - looks very realistic. If you do ground level photos it would be hard to tell your Chief is not the real deal. You seem to set the bar several notches higher on every build!
Posted: Tue Jun 16, 2020 10:04 am
by Ivano Costantini
Hi Phil, I see with regret that the engine has not yet arrived, this morning I had this information from the traceability system:
on day 7, the shipment left the Italian national territory and was taken over by an English postal operator for delivery.
However I think it's an international problem, I still haven't received the bolts ordered on May 26th.
Grazie! Ivano
Posted: Thu Jun 18, 2020 8:18 am
by Ivano Costantini
Hi Phil,
this morning the tracking system tells me that the package is being delivered. Let's hope!
Thanks Ivano
Posted: Thu Jun 18, 2020 9:17 am
by Phil Woollard
I wonder if that means it is out for delivery today? It's so exciting! 8)
Posted: Thu Jun 18, 2020 9:53 am
by Ivano Costantini
in consegna, translates "in delivery"
Ciao!
Posted: Thu Jun 18, 2020 11:32 am
by Phil Woollard
Had to basically paint the numbers by hand. 8)
Posted: Thu Jun 18, 2020 11:46 am
by Vince Cutajar
You've got a lot of time on your hand.
Posted: Thu Jun 18, 2020 12:11 pm
by John Clarke
Frighteningly wonderful, 8)
