Page 83 of 95
Posted: Thu Jun 04, 2020 4:42 pm
by Vince Cutajar
I suspected that in that area you might have a lot of supports. Just followed your drawing.
Posted: Thu Jun 04, 2020 9:17 pm
by Liam Mahoney
Hi Phil
Yes indeed, subtle but effective, very nice on all fronts.
Liam
Posted: Fri Jun 05, 2020 7:06 am
by Phil Woollard
Hi Liam I knew you were following, I will do another smoke trial very soon as Adrian is upgrading the smoke control units for me, basically my high pressure system draws a little to much current but it's all in hand. I'm excited to finally perfect the high pressure smoker and I think I'm nearly there, a convincing smoke signature in my opinion is so important in our scale, even more so for the Smokey old multi fuel two stroke main engine and of course the little gue synonymous with the Chieftain! It's all good fun and entertaining for all.
Posted: Fri Jun 05, 2020 8:25 am
by Phil Woollard
For Vince , the flywheel in 1/6th and for comparison the 1/35th, it's big!
Posted: Fri Jun 05, 2020 8:52 am
by Vince Cutajar
I have that strange sinking feeling that you might find that it's too big. Bye the way, I made that recess on the side 15mm instead of 10mm.
Posted: Fri Jun 05, 2020 8:58 am
by Phil Woollard
I'm off to the workshop in a mo to measure the slice needed, I think it's to big but I can easily scale it down on the printer
Do you fancy having a go at the flex plate ring gear? It's the same diameter but but a whole lot thinner.
Posted: Fri Jun 05, 2020 9:06 am
by Vince Cutajar
No idea what's that.
Posted: Fri Jun 05, 2020 9:16 am
by Phil Woollard
There's a photo, I think the teeth will print ok. 93.3 od with a thickness of 7mm
Posted: Fri Jun 05, 2020 10:16 am
by Vince Cutajar
Photo??
Posted: Fri Jun 05, 2020 11:07 am
by Ivano Costantini
URGENT for Phill,
I need a phone number, send PM message
Posted: Fri Jun 05, 2020 11:49 am
by Phil Woollard
Message with phone number sent ivano.
Vince 70mm od looks really good , I tacked the photo on the previous post.
Posted: Fri Jun 05, 2020 4:30 pm
by Vince Cutajar
How's this before I make a mirror copy?
Do you have any hair left?? I suspect the supports of the rotor and stator will make you pull whatever hair you have left.
Posted: Fri Jun 05, 2020 5:52 pm
by Phil Woollard
They look very good indeed Vince ! There will certainly be a lot of support with that print.
Posted: Fri Jun 05, 2020 6:14 pm
by Vince Cutajar
OK. I'll make the mirror copy and send you the file.
Played around with that gear thingy you mentioned but was not sure exactly what diameter you wanted. This is about 93mm and 125 teeth. I could make more teeth but I suspect they won't print well.
Posted: Fri Jun 05, 2020 6:18 pm
by Phil Woollard
That will print just fine, the fans are about the same diameter on the little model, I can reduce it this end as 70mm looks about right to me.
My plan would be to build a complete L60 as a standalone model on a pallet ready for the Stalwart Reme vehicle to carry in the rear cargo area.
