Page 9 of 11
Re: Easy Eight No22
Posted: Sat Dec 07, 2024 3:59 pm
by David Hartwell
Switch positioning.
Started with the system power switch. Drilled the little hole for the external tab washer in the little box thingy the switch mounts in. Then some off the shelf angle for a couple of brackets.
The fixings go right through the box with locknuts on the other side.
Then marked its position under the deck keeping it parallel to the filler cap mountings.
Then marked and drilled fixing holes.The correct length fixings will be used on final assembly.
Had a slot machined in the filler cap with plenty of clearance for the toggle sticking through the deck.
Just enough toggle sticking through to operate. Some little stickers for once it has all been painted.
That is that one completed.
Then made a top hat bracket for the smoke unit switch.
Slot drilled and filed for the switch.
Mounting holes drilled and painted.
Hole punch used to enlarge existing hole.
Nibbed off the sharp edges on the new hole then mounted the switch like so.
View from above.
View from above.
Completed. Just the middle filler cap to do.
Re: Easy Eight No22
Posted: Sat Dec 07, 2024 5:15 pm
by Derek Attree
Hi David
That's a very neat solution for the switch
and a very good build of this E8.
Regards Derek
Re: Easy Eight No22
Posted: Mon Dec 09, 2024 6:24 pm
by Robert E Morey
I've used those filler ports for charge sockets, but never switches. Clever location and nice details!
Re: Easy Eight No22
Posted: Tue Dec 10, 2024 7:33 am
by David Hartwell
Thank you for the comments Derek and Bob. As you say Bob they could be used for charging sockets, another good idea. I am hoping if all goes to plan, which it sometimes doesn't, to put a main battery isolator and charging sockets under the front hatches. And the middle filler cap on the rear deck will be the fill point for the smoke unit, hopefully. I need to confirm what thread is used for the filler tube on the smoke unit before I do that but busy on other things at the moment.
Regards Dave.
Re: Easy Eight No22
Posted: Sun Dec 15, 2024 1:47 pm
by David Hartwell
So to the final part of the grill bars.
Once the 638 had cured found a way to hold them in the vice. Then filed the backs of the blocks to match the tube.
Like so.
Like so.
A little bit of prep and then a coat of primer to check the finish.
Then assembled and lined everything up. Then drilled through the deck for the second fixing in the pivot blocks.
Drilled and tapped the back panel for the two fixings in that block. Now I could mark and cut the inner bars.
Like so.
Like so.
Then fixed the remaining outer tubes with 638 and once cured a bit of prep and paint.
The button heads will be replaced on final assembly. I think hex heads will look better.
Just a few pics to finish off.
At last, they are finished.
Re: Easy Eight No22
Posted: Sun Dec 15, 2024 2:02 pm
by simon_manning
Very Nice, regards simon.
Re: Easy Eight No22
Posted: Fri Jan 03, 2025 4:44 pm
by David Hartwell
Thank you for the comment Simon, much appreciated.
Decided to build the Armorpax 50cal. It is a lovely kit supplied by Dave and goes together with the minimal of fettling. Really enjoyed building this up.
Took care when fitting the barrel to the main body making sure it was inline.
One tiny mod. I drilled a 2.1ish hole up the end.
I like the way the  parts pin together.
Still need to make up the ammo box but I don't need that at the moment.
So now I have built that up I can work out the front support bracket.
I am guessing that this must sit at an angle when it sits in that support thingy as I can't find a photo of it in use.
So armed with a rough measurement I think I will make up something and see what it looks like.
Re: Easy Eight No22
Posted: Fri Jan 03, 2025 5:21 pm
by Kevin Hunter
Any help?
Kevin
Re: Easy Eight No22
Posted: Fri Jan 03, 2025 5:47 pm
by David Hartwell
Thank you Kevin, that is exactly what I was after. You have no idea how long I have spent looking for a picture like that.
Looks like my very temporary red plastic box height was almost there. Once again thank you for helping.
Regards,
Dave.
Re: Easy Eight No22
Posted: Tue Jan 21, 2025 5:40 pm
by David Hartwell
To finish off the 50 cal I started looking at the ammo box.
What I wanted was the lid hinged but in the fully open position. I wasn't going to attempt drilling the tiny little hinge points and even if I could I don't think it would have fully opened because of the positioning of them. So I found a 40mm dolls house hinge was about as close as what was there.
Filed all the little lugs off.
Set the hinge in the box side and loctited like so. A little bit of filling. At the end of the day you won't see this anyway.
I think that will look ok once painted.
So now I had the lid pivoting I decided to make a replacement locking bar catch thingy, whatever its called, and have that pivoting as well. I couldn't use the original as it didn't have enough at the ends to go up the tube. Some 2mm tube and 1mm round bar.
Filed the bit off the edge of the lid.
Then loctited a piece of the 2mm tube on.
Then a little skim off filler either side of the tube to give it a little more strength and fitted the replacement bar handle catch thingy.
All pivots nicely.
All pivots nicely.
I think it looks ok. Into the paint queue and must remember to order a couple more of these boxes for the luggage rack.
Re: Easy Eight No22
Posted: Tue Jan 21, 2025 9:25 pm
by Vince Cutajar
Nice mod to the ammo box and no special tools required to do it.
Re: Easy Eight No22
Posted: Sun Jan 26, 2025 2:00 pm
by David Hartwell
Thank you for the comment Vince, much appreciated.
Onwards we go.
Started by making the curved bracket for the sledgehammer and drilling and filing the slot.
Now I have the measurement for the rear leg.
Made like so and fixed to a plate for a spot weld. Pretty sure it goes half way ish across the top of the curved section.
Filed out for the rear leg.
Fixed like so.
Fixed like so.
Yep, happy with that.
Then drilled and filed a little slot for the other bracket.
Wide enough so the bracket can hook through.
Fixing added.
Fixing added.
That will be filled and a little fake weld added later on.
Then made up a plug, like I did for the spanner, to fill the hole in the deck.
May not look pretty underneath but does the job.
Tiny bit of filling to do at prep stage.
Apart from the tying down handle looking thingy, whatever its called, I think that little area is almost complete. Now onto the rest of the tools.
Re: Easy Eight No22
Posted: Sun Feb 09, 2025 6:21 pm
by David Hartwell
So whizzing along at max snails pace, onto the axe.
After going round and round in circles looking at pictures I decided to put a slight angle on the top of the bracket. I'm still not sure if that's correct but it seems to grab the blade better when the axe is slotted in. It will all make sense.
Bent like so.
Bent like so.
Hopefully end up something like that.
Cut the hole out.
Cut the hole out.
And made plug up.
And made plug up.
Underside.
Underside.
Topside.
Topside.
Then I slid the bracket in and inserted the axe head to the point I wanted it to stop.
Then marked on the underside for the bends.
Bent like so.
Bent like so.
Fixed on.
Fixed on.
Then marked for the bracket the other end and made one the same as the one on the sledge hammer.
I think that will look ok with the weld added. The main thing is it grips the blade nicely so it isn't rattling about.
There is a little bit of compromise on the spacing here and there but reasonably happy so far. Started on the pick axe but more on that next time.
Re: Easy Eight No22
Posted: Sun Feb 16, 2025 4:38 pm
by David Hartwell
Continuing with the pickaxe.
The first two brackets were basically the same as for the spanner, just smaller.
Fixed like so.
Fixed like so.
Now the u shaped bracket. After much scrap production I found the minimum amount of shank I could get away with was 5mm up the bracket. Any lower and the spot weld burns through the bottom edge. I will need a 2mm spacer under the deck to get the top of the cut down bolt level with the top of the deck. It will make sense.
Then trimmed the sides to the size required.
That's the 5mm of shank I was talking about.
Then made the other parts.
Hole in the deck cut out.
Then filled the u bracket up to the top of the shank.
Bracket fixed to baseplate. I shall use a locknut on that at final assembly.
Then the 2mm spacer slides on.
Fixed to the underside like so. All things being equal, the filled section should be level with the top of the deck.
Like so.
Like so.
So that is all the fixings underside.
And topside.
And topside.
Deep breath, onto the shovel.
Re: Easy Eight No22
Posted: Thu Feb 27, 2025 5:54 pm
by David Hartwell
This is going to be over two posts as there are too many photos for one. Onto the shovel.
After some practice bits marked out for the bracket.
Cut out like so.
Cut out like so.
Then 45deg. bends to start the top curve.
Then applied the curve.
Like so.
Like so.
Drilled for the hole cut out.
Filed like so.
Filed like so.
Then made a plug up and set the height for the fixing bends the same as I did for the axe.
Let's not spend too much time looking under here.
Really pleased how that looks.
Nice snug fit.
Nice snug fit.
So now this end is done I can mark for the bracket the other end.
I will show you how I made this one for the other end next time.
