Steves Panther A
- Has liked: 8 times
- Been liked: 701 times
Re: Steves Panther A
Over the last few weeks I've been busy fitting the electrics to the hull, motion,sound,smoke,working Notek headlight and taillight, independently opening drivers visor and gunners flap with mg LED.
- Has liked: 2519 times
- Been liked: 444 times
You certainly have the wiring very tidy, batteries on the side is a nice touch and will provide extra space.
Your tool brackets are nicely made adds a lot to the model I would be interested to see the MG working
Hi Mark
The batteries had to go on their sides because the recoil unit which was designed for the Elefant is much longer than the standard item. There is a problem when the gun is fully elevated if the batteries are in their normal vertical position, the lower back end of the recoil mechanism can strike the top of the batterie. Laying the batteries overcomes this problem but the packaging of all the components within the tank is quite tight due to me adding a engine bay and radiator details.
If someone can post a tutorial on adding video to a post I will show the operation of the mg flap and drivers flap.
Ok, couldn't remember my google log on so have used Facebook instead.
- Been liked: 741 times
Hello Steve,
I cant see you movie on fb?
I'am struggeling now with my new graupner mz 24 hott
regards Yves
regards Yves
Front mud guard detailed and fitted, just need to fit the other side and add a couple of mounting bolts to the hull side plates.
i like the modifications you have done with the front mudguards, very nice work.
A bit of a milestone reached tonight as the hull is now complete with the exception of the final paintwork.
- Has liked: 161 times
- Been liked: 831 times
Excellent work Steve! Those pivoting hatches are awesome! Is any of the pivoting hinge part of the kit? Love the latches/stops as well. Beauty all around.
Hi Bob
I have used the supplied kit parts, the only bits I altered were the steel lift bars which had small brass pins added to act as guides and the brass guide tubes that the lift bars slide through which had guide slots cut in each to allow the hatches to close in the correct position. To keep the hatches in the open position I added small detents to the brass tubes that the brass pins drop into.
My attention has now turned to the turret, basic assembly has been carried out with no major issues to report. A few of the csk screw holes in the side plates needed a little pulling but nothing major.
It is important at this basic assembly stage to get the turret sides,front and rear to be flush with the bottom of the turret base plate, any overhang will run the risk of fouling the engine deck forward cooling fan intakes or the engine bay hatch itself.
- Has liked: 792 times
Hi Steve
I have been quietly following your progress and picking up tips. What filler are you using? Is it car body filler or JBWeld?
