Panther Jagdpanther tracks
Russ Clark
Re: Panther Jagdpanther tracks
Post by Russ Clark »
Just wondering
Dose anyone know how many links per side go on the panther A tank?
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Hi Ross,
On all Panthers (Ausf D, A, G and Jagdpanther) it was 86 links / side.
It´s all in the details!
Russ Clark
OK Thanks
vincent hung shu yue
Been liked: 24 times
Post by vincent hung shu yue »
Hi all
In case there is broken, damage track, pins or collars, please let me know and will replace later.
Vincent
Hi All
Still have one set available because one order back out.
Vincent
After completing the steel tracks , I found out the track link can not sit on the centre of the driving teeth. So this need a minor alternation between the distance of the two driving teeth. For measurement, it need to be wider for 2 mm. But I just put two 0.75mm spacer to enlarge . That is 1.5 mm. And the outcome is very good. Here is the photos.
Vincent
Both teeth at the centre point
Filled up the gaps
Filled up the gaps
Spacer add
Spacer add
Gerhard Michel
Has liked: 3 times
Been liked: 677 times
Post by Gerhard Michel »
I would prefer to make a 'starhex' spacer fitting the shape of the sprocket.........
Gerhard
After widen the two driving teeth for 1.5mm, and below is the test run. It sound good. Actually 1.5 to 2 mm are both fine.
Vincent
Gerhard Michel
Has liked: 3 times
I also made test runs with the unchanged sprocket width before driving outside, and all these runs at the testing bench were satisfying. Only in the field, with turns upon grass and earth, my problems began........
Gerhard
Russ Clark
I got these tracks for my panther A some fit well some way off, a wish I saved my casb :?
