Panzer III build
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Thanks Stephen, You have just confirmed, what looked right on the side guards, but as they run the length of the tank and a noticeable feature it was worth doing, have you managed to get any tank building done, as you said you were travelling
regards
Jeff
Has liked: 1037 times
Hi Jeff
When I'm travelling, keeping in touch with yours and other great builds is great therapy.
Had a few hours spare today and made a start on making the extra brackets for the rear end of the catwalks. I'm also going to have a go at the front ones which are tubular and will need some heavy duty silver soldering which is new to me. Here's a photo of the Bovington one.
All the best. Stephen
colin fairweather
Been liked: 9 times
Post by colin fairweather »
thanks jeff
will have a look at cheep plastic cars :)
regards
colin :D
2006 222 SOLD
2009 pzr111 046 SOLD
Jeffrey Goff
Has liked: 20 times
I managed to sort out the machine gun flash with help (thanks to Paul Morris) and am back building, tonight I started to make the sprung loaded catches that hold the mud guards in place, a bit fiddly as the main body is only 3mm wide, the compression springs
are only 2mm wide and take a 1mm shaft, three more to assemble
regards Jeff
Brian Leach
Been liked: 3 times
Post by Brian Leach »
Jefferey,
It is always a pleasure when you have posted something.
I had expected I would try and make these when I get my Tiger, now I know it is possible.
Nice, very nice, and thank you.
Brian
Jeffrey Goff
Has liked: 20 times
Just fitted the catches to each of the mud-guards, the rear ones hook onto a bracket underneath
regards Jeff
Kent Wiik
Post by Kent Wiik »
Very impressing build Jeffrey!
Museum quality, I like that.
Inspiring to see that there is other as well taking the time and effort to have their kit highly detailed and accurate.
Keep up the good work.
Been liked: 1732 times
hi jeff,its hard to keep remembering its a model in some of the photos, looking very real, always a good post, regards simon manning.
Brian Leach
Been liked: 3 times
Jeffery,
Yes I have to agree with Simon, aside from the last picture in this last post, they looked to be the real thing.
Thanks for the sharing good work!
Brian
Jeffrey Goff
Has liked: 20 times
finished all the electrics, and I am going to finish detailing the side guards / fenders before starting on the hull, just added some small details, angle brackets between fender and front hull, and between the fender wheel posts
regards Jeff
colin fairweather
Been liked: 9 times
very tasty jeffrey looking good :)
colin :)
2006 222 SOLD
Jeffrey Goff
Has liked: 20 times
Whilst fitting out the side track guards I noticed that the engine air intakes sloped with the shape of the rear deck, but pictures show the bottom level with the guard, then checking pictures of the PZIII and Stug it became clear that the track guard had an upward facing lip running the length of the air intake, making the side of the intake appear tapered, if you have sectioned the guard, it is easy to remove that section, bend a lip and trim off the excess, not sure if this is of any use to builders of the PZIII and Stug, but it will be much quicker to do before fitting the track guards
regards Jeff
Has liked: 1470 times
Been liked: 1642 times
Looking at the Panzer Tracts diagrams, I think the air vent IS tapered, with vertical sides and the top shaved to follow the level of the deck.
This is the Panzer III N from Bovington:
I looked into replacing the upper side panel, so that the vent was set back correctly but what with the angled top and the asymmetrical inner baffles, I've decided to try and make new ones from scratch.
Jeffrey Goff
Has liked: 20 times
Hi Adrian, you might be right on it being tapered, but this picture shows the rear of the air intake going below the guard
regards Jeff
Brian Leach
Been liked: 3 times
Adrian,
Found some good picts of the Air vent at this site.
Maybe this will help: http://www.peachmountain.com/5star/US_A ... _tank.aspx
Nice work!
Brian
