Pz 87 Leo of the Swiss Army
Andre Meylan
Has liked: 802 times
Been liked: 362 times
Re: Pz 87 Leo of the Swiss Army
Post by Andre Meylan »
Adrian Harris wrote:
Fri Mar 14, 2025 11:39 pm
There doesn't look to be much elevation available before the servo arm hits the bracket :?:
Thanks Adrian and yes, that's one thing to find out ... at worst I can cut out the bracket so it will still be strong enough.
My gun barrel will be in carbon and the weight is hopefully between 300 and 400 grams instead of 1.9kg in metal.
Best regards, Andre
Andre Meylan
Please don't judge me on a piece of wood in a tank, particularly in a modern one ... :P
The 10mm increment allows for free travel of the servo, so I will not have to reduce the end points in the radio but can use full way.
Cheers, Andre
Chang
Has liked: 16554 times
Been liked: 487 times
Post by Chang »
Andre Meylan wrote:
Sat Mar 15, 2025 6:47 am
Best regards, Andre
Hi Andre. Very interesting to see a Carbon gun barrel. Is there any photo to see it in the whole length ?
What is the diameter of the Carbon tube?
With regards,
Lerh Chang
Andre Meylan
Hi Lerh,
I have not done the gun barrel yet. The carbon tube is 45/41, meaning 45mm is the outer diameter, just like the CV0473. I will use the original CV0422 adapter to the barrel pivot. CV0424 will be 32/30 carbon tube. CV0425 will be moulded and then also made out of carbon, but I have not done that.
Cheers, Andre
Andre Meylan
Finishing the smoke system and "glueing" the copper pieces together using a gasket silicone. This allows me to disassemble (vs. soldering) far more easy. It should be smoke-proof and heat resistant. I also have more time to place the pieces together.
Cheers, Andre
Erichornby
Has liked: 27 times
Been liked: 5 times
Post by Erichornby »
Andre Meylan wrote:
Wed Oct 09, 2024 4:32 pm
Going forward with the wheel / tyre assembly ... as mentionned in the forum, the tyres need more surface to be glued on, otherwise there is a risk of shearing-off the wheel rim. So I make a first attempt with a foam rubber that I cut out of a 2mm sheet. It is slightly too thick, yet with the pressure of the tyre I hope to depress it a little ... first wheel is glued using Loctite 480 ... let's see tomorrow!
Cheers, Andre
Hi Andre,
I'm very interested in the problems associated with fixing the rubber tyres, I'm just about ready to start myself. Have you managed to prove anything with your "Packing Pieces"
Eric Hornby
Andre Meylan
Hi Eric,
I have not yet tested whether everything will fall apart :|
But I am confident that with the inlets glued in, the tyres should hold firm.
Cheers, Andre
Martin Usher
Has liked: 25 times
Been liked: 62 times
Post by Martin Usher »
If it helps any i had used a rubber sheet of 1.5mm thickness to fill the wheel well.
Grit blasted the wheel for adhesion, 480 black as bond agent, scotch-brite the rubber to rough up and glue.
With the wheel well the same circumference the tyre now sits across fully.
Allowed a day to cure then the same with the tyre, roughed and 480 to bond.
full contact across both wheel beads and filled well, no issue so far.
Martin.
Andre Meylan
Martin Usher wrote:
Wed Mar 26, 2025 4:48 pm
Martin.
Thank you Martin. That's excactly how I did it. Best regards, Andre
Erichornby
Has liked: 27 times
Been liked: 5 times
Many thanks gents, will obtain some material and proceed with some confidence :)
