OPEN ON THE 6TH FEB 2025
Has liked: 777 times
Been liked: 1745 times
Looking good Phil. You even managed to use that exhaust coupling between the engine and exhaust box. I did not really like the drawing I did for it hence the reason why I never mentioned it.
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Phil, the amount of detail you are cramming in there is just plain crazy. In a very good way, obviously!! :D
Amazing work.
Has liked: 2267 times
Been liked: 7152 times
Thanks guys although I have slowed down a bit to let Ivano catch up.
John the smoker is, as it was just hiding under the floor. I will need to cut slots in the vertical floor step to allow the air in and the sound out, and that speaker is loud and can cope with the large output from the sound module. I may even add another speaker somewhere for the top end sounds, i also have one of adrian's smoke control modules which has been configured to run with the sound board which should slot in there to I hope.
Vince the exhaust fittings are great, I'm not sure if those s shaped collectors will fit just yet but I can always print longer ones.
Kevin I like creating the almost impossible it just takes some imagination.
How about this interior, the accurate armour Antar kit!
Kevin Hunter
OMG :D
Has liked: 132 times
Been liked: 784 times
Nice work Phil and Vince - you've taken this model to a new level. Those printed bits look awesome, esp if the floor is painted black for contrast. You've demonstrated the niche home printing can fill for customization and details!
Great stuff!
Been painting, weathering and wiring today. 8)
No weathering on the radiator as yet, and boy does it need some!
Don't leave that 1/6 spanner where it can vibrate off into the 1/6 drive clutches! Fantastic detail.
B
Chang
Has liked: 16060 times
Been liked: 452 times
Post by Chang »
Robert E Morey wrote:
Fri May 22, 2020 1:39 am
B
Also to that black canteen cup...... :D
Hi Bob hi Chang, I'm using a matt black shade on the false floor inside that hull and your are right the contrast works a treat!
Today's task is to get a drawing to Vince of the gue engine with as many dimensions as I can guesstimate, if anyone has any info on the gue please share, and photos or drawings would be great. 8)
Difficult to see much of the gue in this photo
Is this the bottle jack you wanted?
Just to give you an idea of size, the cylinder is 12mm and it is 30mm tall. So I guess you will have difficult printing the smaller parts like the Sterling (I guess the Sterling never printed well).
Remember to keep it simple!
Vince that Jack will be great for the kit locker details and for my little diorama's , I can use some brass rod for the handle!
Ref the gue drawing, I am a simple guy so a simple sketch will be easy! :lol:
The sterling is a tricky print for sure, it's getting all the supports removed that's the problem and I've been side tracked with the engine bay but I will crack it!
Shall I send you the stl of the jack?
Yes please, I will fire up the printer. I may increase the size to get a larger version of the same jack. 8)
File sent.
I used actual dimensions for a 6 ton jack.
