OPEN ON THE 6TH FEB 2025
Been liked: 1802 times
I think Armortek medals should be handed out here :wink: , this is way beyond the call of duty :mrgreen:
Has liked: 777 times
Been liked: 1744 times
Or an Armortek baseball cap.
This is what I sent Phil today as requested.
Brake fluid reservoir
Hydraulic reservoir
Hydraulic reservoir
Has liked: 2267 times
Been liked: 7152 times
More done. 8)
Vince I'm going to increase the hydraulic tank by 10% as this looks a little small.
The brake fluid reservoir look pretty good.
I've fitted the geu exhaust pipe but left it long until I get the engine from Ivano the final bends and length are unknown.
The bracket for the brake reservoir and the two pipe couplings on the hydraulic reservoir seem to have printed well. Phew!
I agree the detail is very fine! 8)
Andy McMath
Has liked: 13 times
Been liked: 22 times
Post by Andy McMath »
Phil,
Thanks for the barrel insert, 10/10 fits like a glove and looks the part.
Andy
Well it was really down to Vince, I just printed them out! Glad you like it, the little boxes for shipping are a bit gay but that's all I could find on the net. :roll:
Keep building and keep posting.
John chamney
Has liked: 5 times
Been liked: 2 times
Post by John chamney »
Cheers Phil received the rifling today , looks fantastic , those boxes are dangerous though , misses seen it and thought she had a present ! :roll:
Enjoy john and keep that little box safe! :roll:
Been working on the hydraulic tank and it's subunits, sounds good subunits, all the bits that have oil at pressure running through them! 8)
I have to be able to disassemble everything so I have to decide where or which panel the different units are bolted to, if I'm not careful they conflict and you have 30  bolts to undo instead of just 8.
Hydraulic lines waiting to be connected to the gear box actuators.
Vince there's plenty of room for that gearbox slice. I should get it back any day now. Shall I send it to you or  send you drawings and photos.
Ivano Costantini
Been liked: 735 times
Post by Ivano Costantini »
If the front of the grill is positioned correctly, it should be cut at this level.
taglio griglia.jpg (105.45 KiB) Viewed 642 times
Drawings and photos should be OK. As your model of the gearbox is 1/35 scale do you think you can get clear photos of it? If yes, then I will need four photos of the four sides (one photo per side). Also, very important, a photo of the top of the gearbox.
We'll see how it goes from there.
Looking at your photos, I estimate that the slice of the gearbox will be around 10mm deep.
Ivano Costantini
If you like, you could also create this small "crankcase" with an L-profile
taglio griglia con carter.jpg (48.77 KiB) Viewed 638 times
Today I made a rough sketch of the body of the gearbox, the brackets (a bit shortened) and the exhaust box to have an idea of what I will be dealing with. I haven't done anything on the face of the gearbox which faces the engine.
Without exhaust box
Without exhaust box
Side view
Side view
Could you tell me the distance between the false bottom (where the slice of the gearbox will sit) and the ceiling of the engine deck so that I can figure out what sort of thickness of the slice I will be dealing with.
