Pz III New Build
- Has liked: 126 times
- Been liked: 755 times
- Has liked: 1024 times
- Been liked: 2093 times
This is a bit of a repeat. Having made the Sehklappe mechanism in mild steel, I decided I couldn't get the detail right and opted to re-make them in ally. At least I've been able to get a more accurate shape and mount the frame with cone head bolts to check the external appearance.
Next comes the critical bit of working out the size and shape of the swing arms to get the right movement.
The vision ports completed
Finally got around to finishing the vision ports - thanks Tim for setting to challenge of getting them working.
Firstly, the swing arms, which follow the full size shape:
This is the full set of parts for one port:
Here, the completed arrangement:
The ports were different. The starboard side was a Sehklappe 30 without vision block (ie a solid cover):
On the port (driver's) side, the port had a vision block. Although I haven't made the block, I did mill the slot, in the correct position below the centre line:
I'm glad I made the effort - even if I can't work out how to open them from the outside.
- Been liked: 177 times
Hi Stephen,
First of all, first class work on the vision port mechanism. I love the photo of it in the open position. Second of all, I didn't mean it so much as a challenge(as I know you are more then up to the task). It was more of a "We'll now that you mentioned it, you gotta do it" sorta thing.
The end result is superb and I think will add a great level of detail to your Panzer III. I think it's only fitting to bring your upper hull to the same level as you did on the lower hull.
Just beautiful all around! Great inspiration. Looking forward to future photos.
- Has liked: 1371 times
- Been liked: 1567 times
- Been liked: 19 times
- Has liked: 218 times
- Been liked: 180 times
- Been liked: 1634 times
- Been liked: 10 times
Engine Decks
I've now started on the upper hull. I've modified the Armorpax lifting hooks to give them the correct shape and drilled out the cast bolts and replaced them with 7BA drilled and tapped into the deck plates.
At the back end, I've started on the engine intake covers. These were supported with eight brackets per intake cover. So today, the mindless task of milling a batch of 40 blanks. The reward came with assembling the first one seeing the overall effect. The shape of the bottom surface of the cover isn't quite correct on the model, it's flat but on the real thing there are subtle curved lips at the corners. I've debated how to do these and will probably settle for Milliput.
