OPEN ON THE 6TH FEB 2025
JT in Germany
Been liked: 1654 times
Re: JT in Germany
Great camo peter, on first glance sat on a table seems to stand out but outside in the leaves, very effective, break's the shape up, regards simon.
Charles A Stewart
Has liked: 500 times
Been liked: 913 times
Re: JT in Germany
Post by Charles A Stewart »
It's just above the road wheels.
Chris Hall
Has liked: 520 times
Been liked: 675 times
Re: JT in Germany
Post by Chris Hall »
Wasn't that the operational life of every JT in 1945 ? Go out, kill something, break down ........... :lol:
Has liked: 776 times
Been liked: 1743 times
Re: JT in Germany
Love it. :D
Sad but true.
Gerhard Michel
Has liked: 3 times
Been liked: 650 times
Re: JT in Germany
Post by Gerhard Michel »
Chris Hall wrote:
Mon Feb 22, 2021 10:27 am
Well, I didn'k know that Armortek reproduced the features of the original JT SO true........... :twisted: :mrgreen:
Hello Peter,
nice camo; indeed!
Gerhard
Chang
Has liked: 16049 times
Been liked: 452 times
Re: JT in Germany
Post by Chang »
Hi Peter,
The BIG HEAVY 1/6 JT in 2021, Just like the real BIG HEAVY JT in 1945, once in trouble, are hardly movable. But of course the crew will never abandon it. :lol: :lol: :lol:
Just curiosity, were 22/ February photos shot on the same day with 03/ January photos, and the way before 09/ February in snow field ?
Regards, Lerh Chang
Peter Quambusch
Been liked: 995 times
Re: JT in Germany
Post by Peter Quambusch »
Chang wrote:
Mon Feb 22, 2021 2:41 pm
Hi Peter,
Regards, Lerh Chang
Hi Chang,
The pics I post are shot same day as posting. Only for bigger event pics (e. g. Hausen) they might be a day or two old.
Peter
Peter Quambusch
Re: JT in Germany
Started to add some details to the cat...
Chang
Re: JT in Germany
Post by Chang »
Hi Peter,
Always nice to see added details to make it unique. The four 2-T crane mounts or "Pilzen" around the top-middle of the casemate, to me is such an example.
May I ask how do you add it to the panels? Glue it on or lock it with fastener(s), or both?
Stay safe.
Lerh Chang
Peter Quambusch
Re: JT in Germany
Chang wrote:
Fri Mar 12, 2021 1:33 am
Hi Peter,
Stay safe.
Lerh Chang
Hi Chang,
I use fasteners as much / often as possible. That makes alterations much easier. Gluing is a lot harder to undo. :D
Peter
Chang
Re: JT in Germany
Post by Chang »
Peter Quambusch wrote:
Fri Mar 12, 2021 9:34 am
...I use fasteners as much / often as possible. That makes alterations much easier. Gluing is a lot harder to undo. :D
Hi Peter,
I prefer fasteners to glue too, but haven't sorted out how to lock them on those sloped panels.
Do you drill and then tap a screw hole from inside of the panel through the Pilze, or any other way ? :idea:
Lerh Chang
Peter Quambusch
Re: JT in Germany
Hi Chang,
Yes, drill a hole and fix it with a screw and nut.
Peter
Chang
Re: JT in Germany
Post by Chang »
Hi Peter,
Just found in your photo dated 15 Feb, what is that in red circle? Why was the recoil spring tied with it instead of the position as per the building instruction manual? :?:
1-6 JT-70-2.jpg (240.09 KiB) Viewed 4422 times
Lerh Chang
Peter Quambusch
Re: JT in Germany
Hi Chang,
The circeled part will be attached to the rear of the gun. The pic was taken while dry fitting and figuring out where to place everything. Nothing was finally fixed at that point.
Peter
Peter Quambusch
Re: JT in Germany
Track after being run in... :D :D :D
