Phil Dawe's RR commission build
- Has liked: 2267 times
- Been liked: 7152 times
Re: Phil Dawe's RR commission build
A very busy day in the tank shop.
- Has liked: 127 times
- Been liked: 758 times
You can find em in the sky and on the ground! Really nice details on Lewis and searchlight! Great work. Looks like it would be a squeeze to fit in that thing - so much fun in 120 F heat.
Very cool rig.
Very cool rig.
A pleasant afternoon spent in the workshop, the rear grab handles made and fitted, the semaphore flag racks made and fitted to the turret and pre weathering paint applied.
- R (10).jpeg (53.05 KiB) Viewed 5549 times
Last edited by Phil Woollard on Sun Nov 07, 2021 5:20 pm, edited 2 times in total.
Phil, the rear boarding handles and the rack for the signalling flags looks great.
Lots done.
Working in and around the pointy end.
Now a question for the boss, Tigris had just two bonnet top catches, not three. Should I remove the middle one to make it more correct?
Phil,
Accuracy is the name of the game so only two top hinges as that's what the photo shows.
I agree 100%! I also think that the top hinges are a bit too chunky so need reducing down a tad.
Nearing completion, the stowage starts tomorrow.
- Has liked: 774 times
- Been liked: 1740 times
Yes definitely need to go, so a very small job for tomorrow.
Or move the stencil a little to the back.
You were right about that C being a G vince, Phil picked up on it to, the river Tigris!
Phil, those bolt heads will have to go Also the lettering is a bit undersize if you compare with the prototype vehicle in the photo. Maybe a 10% increase in size for starters?
No problem Phil, I will print a new stencil 10% larger. Yes those bolts are in the way and need to go, I have some tiny countersunk copper rivets which should do the trick!
