My 251 build.
- Been liked: 18 times
Re: My 251 build.
Hello Dennis, when you get the chance please look at Mick's last page, page seven. Maybe you can help us out when installing the Suspension Bush (CM0208). Read my question to Mick and his reply. Thanks Dennis
- Has liked: 10 times
- Been liked: 225 times
Re: My 251 build.
Hi Tom,
The bush CM0208 has to be loctited in to the wheel, then the bush is rotating on the steel axle. If you loctited the bush to the axle firstly the aluminium wheel would be rotating on a bush which would wear quickly, secondly you wouldn't be able to get the inside wheel off if needed.
Re: My 251 build.
Working searchlight now added to the 251 not strictly an Amortek model but I don't expect Gill and Mark will mind. Both under radio control, working video can be found at :-
- Has liked: 1565 times
- Been liked: 835 times
Re: My 251 build.
Hello Dennis, excellent work, I follow your build and enjoy the posts, well done mate. Those 'searchlights' are little works of art......
My 251 is up and running, no problems. looking forward to building the 'Quad'.....Mick
- Been liked: 213 times
Re: My 251 build.
Hi Dennis, outstanding work I can only dream about working to your level of skill.
- Paul Wills
- Has liked: 646 times
- Been liked: 141 times
Re: My 251 build.
Hi Dennis,
I've enjoyed watching this build, your extra detail is outstanding. Did you make the trailer base, or did you buy it from some where?
Paul.
Paul.
- Been liked: 53 times
Re: My 251 build.
Hi Dennis,
Nice addition to your 251, you will be able to race around your grounds at night spotlighting the neighbour hood cats and dogs, and drones and chasing them all away from your fortified bunker!
Ian
Ian
Re: My 251 build.
Hi Paul,
I was given the Flak 38 gun which I mounted in the rear of the 251, it came complete with a trailer and a bit of fabrication later managed to use it for the searchlight. The searchlight came from a Club member that I did some repairs and mods to his Tiger so we did a deal. It originally had a 2.5 volt filament bulb in it so i changed it for a 3 watt high power led and a lot of mods later to radio control it. I was thinking of buying a searchlight from the web until I saw the price £135 plus shipping !!! The Flak 38 was a Dragon model which is no longer available I think, so was lucky to get one free.
