Page 8 of 16
Re: Sd.Kfz.7/1 and 20mm Flakvierling 38
Posted: Fri Jun 20, 2014 8:05 pm
by phil fitzpatrick
Striped it down a bit and started on my electrics,motors first and a few other bits
Posted: Sat Jun 21, 2014 10:24 pm
by phil fitzpatrick
Winch motor fitted
Posted: Sun Jun 22, 2014 12:10 am
by Derek Attree
Hi Phil
Coming along really well.
Will the drive motors go in with out seperating the chasis ?
It looks a bit of a tight fit.
Posted: Sun Jun 22, 2014 6:16 am
by phil fitzpatrick
Thanks Derek,
Yes the motors went in easily,Ive got some more photo's on my camera
that I haven't got round to getting on the computer.
If you have your motion pack aswell before you start,it is a good idea
to fit the little bush that supports the end of the motor shaft,into
the gear box recess at the early chassis stage.
Otherwise you end up balancing it on the end of your finger and poking it through the
hole in the chassis.
mine needed a bit of emery paper for a better fit.
Also the stearing servo might be easier fitting at the chassis stage.
Posted: Mon Jun 23, 2014 4:55 pm
by phil fitzpatrick
Drive Motors fitted
Posted: Mon Jun 23, 2014 9:01 pm
by phil fitzpatrick
Used part of the battery tray for my speaker
Posted: Tue Jun 24, 2014 7:14 pm
by phil fitzpatrick
Stearing servo and linkage
Posted: Wed Jun 25, 2014 8:18 pm
by phil fitzpatrick
Made my own battery tray to sink as low as possible.
Posted: Wed Jun 25, 2014 10:53 pm
by phil fitzpatrick
Made some Sub Decks for my electronics,just enough clearance.
Posted: Thu Jun 26, 2014 8:02 pm
by phil fitzpatrick
My battery set now sits nice and low and room for my power supply.
Posted: Fri Jun 27, 2014 7:36 pm
by phil fitzpatrick
Power supply fitted on top of battery set,access to power button through
engine grill.
Posted: Sat Jun 28, 2014 7:41 am
by phil fitzpatrick
The rest of the electrics sitting on the sub decks,the exhaust system
still to go in,just had to take the screws out of the module covers,
clearance is nill between deck.
The clearance between middle sub deck and winch top bolts is a piece of 180
wet and dry
The black cable protector disguises all the bright colours.
Posted: Sat Jun 28, 2014 8:22 am
by John Fitzsimons
Nice neat layout. Great to see this part.
Posted: Sat Jun 28, 2014 1:24 pm
by phil fitzpatrick
Thanks John
I might spray just the one edge of the speed controller and amplifier module,with
the dark yellow,so that it doesn't stand out so much.
Posted: Sat Jun 28, 2014 8:13 pm
by Robert E Morey
Phil,
Your SDKFZ 7 is looking great. Very nice install with the electronics. Are you planning on the Armored cab? Beautiful job on the rear deck. I'd love to build one of these someday. Fantastic work as always.
