I have spent the last two days trying to get my Late Tiger 1 to turn correctly. I have a Taranis X9D+ 2019 RUNNING opentx version2.3.14-otx.
I also have OpenTX Companion version 2.3.15 on my laptop. I have not updated the transmitter yet as I am concerned I may loose the current Tiger and Churchill settings and will also need to update the receiver . I downloaded the latest version for the SD card but when I put it in the transmitter and power up the transmitter gives a warning it is expecting version 0038. The SD version on the Open tx site is 0039 and there doesn't seem to be a version 0038 as I tried all the earlier dates ones and they all come up v.0039.
So that's the Transmitter and Companion situation at the moment. As you can tell I am not very confident with programming
Now for the actual results I am getting with driving the Tiger.
I am using single stick driving on the right stick, traverse and elevation on the left. I have tried to replicate how Stephen set up his Centurion as that was the only write up I could find explaining it (Thanks Stephen).
I have both motors going forwards and backwards ok. With the right stick staying vertically centred and then moved left and right the tracks do what is expected to turn accordingly, i.e. contra rotate. The problem arises when I move the stick forward, say half way and then move the stick left or right to do a turn. One track completely stops while the other carries on at the set speed. The tank than struggles to turn, especially on grass. I downloaded the Tiger to Companion and have taken photos of my set up. I have tried changing the mix between -100 & 100 on channel 3 and the set up as it stands gives the results above.
Any help would be gratefully received as although it runs I am getting frustrated despite spending hours reading the Taranis OpenTX manual that I cannot improve it. I also want to bring the Tiger to the open day and would like to take it so some shows this year.
I am also at the stage of putting the electronics in the Churchill so having a setup I can work from would be a massive help.
I am away this weekend but would be willing to travel if anyone is able to have a look/assist.
Gary
