1/6 scale Zimmerit
Tom Wittstock
Been liked: 18 times
1/6 scale Zimmerit
Post by Tom Wittstock »
All, Could someone tell me the WIDTH (Horizontal Measurement) for Zimmerit when applying on the KingTiger Tank?
Thanks...Tom
Will Roberts
Has liked: 8 times
Been liked: 29 times
Re: 1/6 scale Zimmerit
Post by Will Roberts »
Hello Tom,
There wasn't a set width for zimmerit and it was applied using a roller. My suggestion would be to look at pictures of the 1/35th zimmerit sets available for the KT, such as the Meng one and do your calculations from that. An auction site has some good pictures. Also zimmerit was not applied after Normandy on the Western Front so if doing an Ardennes KT for example then no zimmerit.
Regards,
Will.
Tom Wittstock
Hello Will, I watched the actual KingTiger at the 2018 Militracks and counted each rolled Zimmerit impression. I came up with 28 rolled marks across the turret . I can do the math from there... Thanks for your help....
Will Roberts
Has liked: 8 times
Meng zimmerit has 27 but not all same width. Good correlation.
