Im using a small point edged file one of the smallest ones as Kent have ordered me to.
I then just let the file bounce in different directions in ca 1 to 1.5 cm in lenght, Thou Kents way is more refined and more precisioned as i learned on the telli today
![Smile :)](./images/smilies/icon_smile.gif)
I try to make uneven shapes with different pressure on the file in stage 2 and somewhat crisscross a bit.
last stage is to make the pits or what i should call em take a little bigger file, still point edge one and make random little stretches and holes. Remember to go on the surface with steelwool to clean it and then with acetone or some other cleaner before you work it .
When done filing clean it with acetone again.
Then etch prime it.
Then staple putty with a brush with short hairs wiich should be rather stiff. Around 60 -70% of the surface wait for it to cure proper.
Then sand the putty down with 1200 fine waterpaper or what its called in english
, as Kent said i have to do a little more sanding so i will. I think i know how much he means but you get the hang as i did.
Just look at some of the plate pics posted and you see how much, then take a clean cloth to wipe the material away with adnd check and prime with primer.
Im also etch priming all plates inside and outside before mounting it.
Might overdo it but i dont want any corroding materials in some weird place. Plates seem anodized but im not taking any chances with this fine model wich have stolen my heart
Hope this explains some of what you wanted to know Adrian.
If not contact the GURU Kent
hes the master im just his padawan hehe.
Freddie
