![Smile :)](./images/smilies/icon_smile.gif)
Idler wheels are now finished and fitted to the tank.
Bolts are not Loctited on any of the wheels at this point.
Remember not to loctite the inner bearing to the wheel or you will not get the wheel on the shaft with the roadwheels fitted.
I have also started the hub caps for the road wheels and idlers with a light scuff up and check for bolt fit.
I have decided that some 14mm x 2mm magnets are going to be used to secure these to the road wheels rather than the recommended Loctite.
After checking to see if the plan is going to work these have been epoxied into the cap.
I have managed to get hold of a sheet of Photo Etch bolt locking plates for these caps from Günter in Germany so when they arrive I get these fully assembled and painted.
Some Bolt locking tabs for the Idler wheel caps are also included.
