Dale easy eight No 65
Has liked: 1484 times
Been liked: 1687 times
Re: Dale easy eight
To think your first Sherman was a mere 15 years ago :D I still use the pictures as a reference.
Dale jordan
Been liked: 514 times
Re: Dale easy eight
Post by Dale jordan »
Good to hear from you again Adrian It's taken me a while to get back into the swing of things like Tim and Vince , I went from 1/6 to 1 .1 scale for nine years with my jeep and Bren gun carrier and living on 2.7 acres , but now back in town in new house but this time with a workshop in my garage 6m x 3.5m with toilet and TV .. Dale
Dale jordan
Re: Dale easy eight
Rear deck fixed down for good .. countersunk holes filled in , fake welds done lots of test fitting and re checking but worth it . Still room for the turret ring to be fitted after I do the front deck Dale
Dale jordan
Re: Dale easy eight
Dale jordan
Re: Dale easy eight
Setting up the shell guard
Dale jordan
Re: Dale easy eight No 65
It took many hours to get the hatch hinges to work properly got there in the end . The second day was to build up the cast surrounds around hinge and hatch openings plus cast texture came up pretty good .Dale
Dale jordan
Added more detail to drives hatch's and modified the air vent machined off back leg off the top part and bent down the rear part . Then cut out a brass the lower section and added fake bolts Dale
Dale jordan
David Hartwell
Has liked: 15 times
Been liked: 397 times
Post by David Hartwell »
Really enjoying following this Dale, well done.
Regards,
Dave.
Dale jordan
I was Just thinking about you David . This works well for us ! The Sherman forum has been slow lately . I'm following your Ideas on lower hull And you can do the same on the upper hull with me if that works for you ? . Whats good about the Sherman you can just bolt on the running gear any time compared to a German tank with torsion bars . Dale
David Hartwell
Has liked: 15 times
Works fine by me. You have tackled the part I am not looking forward to doing. It really helps seeing your work. Couldn't agree more about the running gear, it would just be in the way and make it heavier. Dave.
Has liked: 161 times
Been liked: 830 times
Your hatches look excellent Dale - well done! They are a lot of work to get right - but worth it in the end.
Dale jordan
Inspired by Dave's idler wheels post . I had a go today ... still a little bit extra detail to add
Dale jordan
Dale jordan
Idlers ready for paint Thanks Dave for the heads up . Dale
