Track Tension
Ray Massa
Has liked: 18 times
Been liked: 116 times
Track Tension
Post by Ray Massa »
Just wondering how tight the tracks should be adjusted. I know Armortek says they don't sag like German tanks, but a general guide for deflection would be helpful.
I had one return roller next to the sprocket seize on me (I was able to get it to release) and I have only driven the tank a few yards for testing. There is a lot of pressure on that roller next to the sprocket and made me think maybe I have the tracks too tight. My tracks deflect enough that if I push on the top they will hit the mud guard if that is any indication of my tension setting. And I have about 1/2" deflection between the idler roller and the first road wheel.
Thanks.
Liam Mahoney
Been liked: 290 times
Re: Track Tension
Post by Liam Mahoney »
Hi Ray
Your request in quite interesting but I don’t believe that it is the problem. Yesterday a local enthusiast Ron paid me a visit so I could help him resolve some of the transmitter issues he was having with his just completed M26. When we got it running we noticed a very disturbing squeaking noise from the left rear return roller, once the offending roller was removed from the tank we could see that the steel shaft had galled the brass bush and was on the verge of completely locking. Ron explained that he had not greased or lubricated any of the bushes, we did not have the assembly manual so I don’t know if it is specified or not but I recommend that he remove all of the rollers and lubricate the bushes, bare minimum of a few drops of oil but a good quality grease is the best option.
I would imagine that you may be in the same position, however if you did lubricate the bushes then you may need to ream the bush or lightly sand the shaft to give it a little more clearance so the lubrication will be effective.
However the best solution would be to fit needle roller bearings part number from local supplier NSO-0080-0120-0080-ST should fit, and after some discussion I will be fitting these to Ron’s tank in the next few weeks.
Just my thoughts
Liam
Ray Massa
Has liked: 18 times
Re: Track Tension
Post by Ray Massa »
Liam,
Thank you very much for info! Interesting that it is in the same location as my issue. I did lube all the axles with a dry lub. I will try to lubricate again by squirting some on the end of the bushing after removing the wheel (and hoping it will creep in). To remove all the return rollers and disassemble will be a mighty big problem as all the bolts are buried in the hull with all kinds of stuff surrounding them. Possible, but will not be fun after just getting it all assembled!
I got the one that was frozen, freed up after spraying the end of the bushing with a creeping oil that penetrates in spaces as small as 1 millionth of an inch (supposedly) and left it overnight. Thanks for the bearing info. May have to resort to that in the future. I will be keeping my eye on all the rollers, especially the rear ones as they seem to be getting all the force applied to them from the sprocket.
-Ray
Keith Morgan
Has liked: 18 times
Been liked: 4 times
Re: Track Tension
Post by Keith Morgan »
I've just re-read the construction manual, and I don't believe that there's any mention of lubrication. However, Armortek's advice in the Knowledgebase page at Armortek's lubrication advice page link is to never use wet lubrication, only dry lube such as Rocol Oxylube. I already have several bottles of dry lube for use on my bicycle so I'm planning to go with that.
Nick Chiocchio
Has liked: 40 times
Been liked: 39 times
Re: Track Tension
Post by Nick Chiocchio »
I ran my tank out back for a few test runs. We've had a lot of rain this summer and the grass is wet, really wet, like stepping on a wet sponge. The humidity is also high, consistently above 80%. The tank got wet especially the suspension. On my last run three of the hubs on the return rollers (EV0316) were missing and the outer wheels came off. I was able to retrieve one hub, the others are somewhere in my back yard.
Upon inspection many of the return rollers were hard to turn, two were almost locked in position. So I disassembled and discovered that rust on the return roller shafts was causing binding. The EH0315 bushing in some cases stuck to the shaft, in other cases the shaft had rust and I think it stuck to the housing EV0305A. So I'm pulling them all out (not fun, I have to disassemble the entire top half of the tank) and need to come up with a solution. I was thinking coating the shaft with dry lube, but maybe grease would be better? Would dry lube prevent the rust? If not any suggestions on what type of lubricant to use? - Thanks
Nick C.
Ray Massa
Has liked: 18 times
Re: Track Tension
Post by Ray Massa »
Nick,
That is what I think happened to one of my return rollers right next to the idler wheel on one side. I did not take mine apart - yet. It does not look like it will be easy to get to all the hex head bolts now that all the electronics are stuffed in the hull. Plus, as you said, I will have to disassemble the top half of the tank. I am not ready to do that since I have just completed it and have hardly even driven it outside yet.
I did lube the those shafts with a WD40 Dry Lube product. So far all the rollers are in good rolling shape but I have not gotten anything wet. I really don't plan on it anyway, but damp grass may be enough. Time will tell. I will be running it mostly on a dry area of dirt/sand and bark nuggets.
If I take mine apart, I will be using a heavy grease I think. This may be something that needs occasional maintenance just like any metal to metal rolling part.
-Ray
Has liked: 1386 times
Been liked: 1587 times
Re: Track Tension
I used a white marine grease on the T-34 as that uses steel shafts running through brass bushes for the swing arms.
Seems to have worked well keeping everything moving, and that tank got a lot of running on grass.
Aaron Taylor
Has liked: 28 times
Been liked: 29 times
Re: Track Tension
Post by Aaron Taylor »
Will the dry lube prevent galling?
Steve McEvoy
Has liked: 9 times
Been liked: 111 times
Re: Track Tension
Post by Steve McEvoy »
After reading the comments here l think l might take my return rollers out and grease them with marine grease before l start installing the electrics. l did lube them with normal grease but on reflection marine grease should be more effective with our climate.(I hope)
Gary Richardson
Has liked: 748 times
Been liked: 1739 times
Re: Track Tension
Post by Gary Richardson »
Hi all,
It seems the question about the correct track tension hasn't been answered on this thread as it got side tracked with the bearing/shaft problems.
I have recently acquired Steve McEvoy's M26 Pershing and am looking forward to driving it and attending shows with it.
As some time has now passed since this topic was raised and people have had plenty of time to run the tanks, what is the consensus about setting the track tension.
Gary
Andre Meylan
Has liked: 601 times
Been liked: 248 times
Re: Track Tension
Post by Andre Meylan »
Nick Chiocchio wrote:
Fri Sep 29, 2023 12:50 am
Hi Nick, I was just thinking about my rollers ... if I destroy something when I do it my way ... there should be always grease in my opinion. Working at a regional bus company, I took wheel bearing grease from the large coaches (some red grease, don't ask me ...) and it looks like in the photos shown.
I use alot of it ... the complete room between the bearings is filled with it ...
Cheers, Andre
Nick Chiocchio
Has liked: 40 times
Re: Track Tension
I set my track tension with the tank supported and the tracks off the ground. I leave a little bit of play because if stuff (tall grass, small rocks) gets caught up in the suspension and it is too tight damage may occur. I had some of the steel wheels bend from small rocks. With some play in the suspension you may avoid damage if something gets caught up in it.
I will try and remember to take some photos of my tank suspended so you can see how much play I have and some of the bent wheel rims.
Nick C.
Gary Richardson
Re: Track Tension
Sat Sep 21, 2024 4:40 pm
Hi Nick
Thanks for you input, when I took the wheels off to reglue the tyres I found one of the wheels was bent, presumably due to a stone getting caught up in the tracks. I have been told US tanks ran with their tracks tight whereas the Germans ran with loose tracks. Look forward to seeing to seeing the photos.
Gary
Gary Richardson
Re: Track Tension
Hi Nick
Gary
Nick Chiocchio
Has liked: 40 times
Re: Track Tension
I'm not sure if you can determine much about the track tension from the photos of the tank on the lift suspended. The bent rims can be seen.
As you can see the tank has some wear and tear and hasn't been cleaned from the last time I ran it.
I made a video of the tank with the tracks resting on the lift (not suspended) and tried to pull the track off the sprocket's teeth. The top portion can be lifted but I don't think it can come off all the teeth that are engaged when running. I did run this on mowed grass and dirt and did not have any issues. Maybe it could be tightened a little more?
Nick C.
