Hand made 1/5 scale K2 Black Panther MBT in Korea.
Youngjae Bae
Has liked: 761 times
Been liked: 613 times
Re: Hand made 1/5 scale K2 Black Panther MBT in Korea.
Post by Youngjae Bae »
The turret's frame was constructed from the prepared K2 tank's turret structural materials, and the main gun was applied with pneumatic recoil.
The work video will be edited and shared on YouTube soon.
In Korea, the traditional holiday of Chuseok begins tomorrow.
I hope you all enjoy the rich autumn.
Regards,
Youngjae
Has liked: 794 times
Happy holidays.
Take it easy on the soju. :D :D :D :D
Youngjae Bae
Vince Cutajar wrote:
Wed Sep 27, 2023 4:33 pm
Happy holidays.
I drank soju yesterday according to Vince's advice, who knows soju, which is a drink enjoyed by ordinary Koreans.
My conversation partner was a cat lady, and the side dishes were beef bulgogi, roasted eggs, seasonal pollack with raw pollack, and cabbage kimchi and mustard kimchi.
Youngjae
Youngjae Bae
Youngjae Bae wrote:
Wed Sep 27, 2023 10:05 am
Regards,
Youngjae
A video has been produced and shared.
Youngjae
Youngjae Bae
The shape of the turret of the K2 tank has been completed.
It seems to be completed by wiring, working on details and painting the wires.
Youngjae Bae
Electrical wiring is being carried out to drive the K2 tank using engine power and to use a generator using a brushless motor.
This K2 production work will be completed by November 20th.
Youngjae
Side skirt support work
Charging system and electronic component arrangement
Working with the emergency manual charging connector for emergency use
Installation of a high-capacity gasoline tank
Engine exhaust muffler
Fans for emission of engine Heat
Brushless Motor Generators
Clean up for electrical contacts
Conducting wire operations
Turrets compared to 500CC cans of beer
Youngjae Bae
In this K2 tank, two of the three heat exhaust fans at the back of the tank can be proportionally controlled by engine room temperature in order to maximize the electric energy of the generator using a brushless motor linked to the engine shaft.
When the engine is started, one out of three is always operated, and when the engine room temperature exceeds 60 degrees Celsius, fan 2 and fan 3 are operated sequentially.
If it goes below 60 degrees, the fan stops and the excess energy is stored in the battery.
Youngjae
Youngjae Bae
The K2 tank is being worked on in detail by division.
Headlight connections, left and right turn signals, etc
Left taillights and exhaust muffler
Right taillights
Right taillights
Dummy rear camera
Dummy rear camera
Front light and binding bolts
Driver Hatch, Stopper, Light Sensor
APU DOOR AND DOOR HINGE
Door supporter
Door supporter
Youngjae Bae
In this work, power generation using engine power, various lights, and details were made on the upper part of the body.
Youngjae
Youngjae Bae
The turret rear basket was constructed, motion tests were carried out, and detailed work was provided for completion.
Youngjae
Outdoor unit for turrets characteristic of desert type K2
Balance weight, pneumatic valve, door switch test
Turret rotation test
High angular main gun firing test
Horizontal angular main gun firing test
Youngjae Bae
The air-cooled heat sink applied to the desert type of K2 CPS (Commander's Primary Sight) was added, and the work of DMRS (Dynamic Muzzle Reference System) and IFF (Identification Friend or Foe) was carried out.
DMRS is a laser fired into the reflector at the end of the main gun, but in this K2 model, it was made of a turret searchlight.
K2 is undergoing detail work. In this photo, a smoke bomb and radar are constructed to be used for the turret's lower paint, handle, and softkill.
Youngjae
Smoke bomb
Smoke bomb
DMRS and IFF
DMRS and IFF
CPS
CPS
Youngjae Bae
This week, the K2 tank also carried out various details on the turret.
All work is expected to be completed by next week.
Youngjae
Youngjae Bae
The K2 tank is undergoing its final painting work, and after 3 days, all the work will be completed,
so I will move the work from the workshop to the house and meet with my chieftain.
Youngjae
Paint3
Paint3
Paint2
Paint2
Marking
Marking
paint1
paint1
Last edited by Youngjae Bae on Fri Nov 17, 2023 11:21 am, edited 2 times in total.
Jae-seung Roe
Has liked: 316 times
Been liked: 134 times
Post by Jae-seung Roe »
Youngjae Bae wrote:
Thu Nov 16, 2023 8:56 am
Youngjae
Superb quality ! one and only dunkelgelb coloured K-2 Black panther! can't wait to see it soon! :D
Amazing how a little paint changes the look and brings it all together.
Can't wait to see a final video of it running around.
