Dale easy eight No 65
Dale jordan
Been liked: 429 times
Re: Dale easy eight
Post by Dale jordan »
Thanks Bob I thought so . I replaced all bolts to SS on my other models plus use Nyloc nuts . I did use steel bolts on engine mount etc ...
Dale jordan
Re: Dale easy eight
Test photo
Recessed the gun mount today I'm using Andy's hobbies 1/16 scale easy eight as a builders model and noticed around the machine gun mount was a circular weld which is under the rain cover mount I've just added today as well . In the photo below Dale
Dale jordan
Re: Dale easy eight
I'm looking at fixing the top decks down permanently and cutting the engine deck out to lift off like the real Sherman . Which I did on my old sherman Dale
Dale jordan
Re: Dale easy eight
Dale jordan
Re: Dale easy eight
The hull is all tighten up now , so I started on the hull fake welds today . Next job will be the engine deck bulkhead I'm going to cut out the flat part of the deck the same as the real Sherman Dale
Dale jordan
Re: Dale easy eight
Dale jordan
Re: Dale easy eight
David Hartwell
Has liked: 10 times
Been liked: 333 times
Re: Dale easy eight
Post by David Hartwell »
Lovely neat job there. Looking forward to seeing the top deck mods.
Regards Dave.
Has liked: 133 times
Been liked: 784 times
Re: Dale easy eight
Looking good Dale. Good progress.
Dale jordan
Re: Dale easy eight
Sherman Build has been very slow lately ! settling into new house . Time for modelling going my way now . I'm making up a template for centre bulkhead right angle to deck sides looks like enough room for batteries so far , the engine deck will removable , same as real machine . I've finished the lower hull so far I like to have all the basic hull and deck work done first before the running gear and detail parts A lot different to building a german tank . Dale
Dale jordan
Re: Dale easy eight
David Hartwell
Has liked: 10 times
Re: Dale easy eight
Excellent idea Dale, really looking forward to seeing this evolve.
Regards,
Dave.
Dale jordan
Re: Dale easy eight
Dale jordan
Re: Dale easy eight
Metal work done , just test fitting so far . I cut up the Armortek rear deck to make the side rear fillets , later I will make a new centre deck with added detail . looks like I still have good access for the motion packs Dale
Dale jordan
Re: Dale easy eight
