Martin's Panzer IV
Robert Tanzer
Has liked: 1113 times
Been liked: 989 times
Re: Martin's Panzer IV
Post by Robert Tanzer »
Thanks for sharing your fine work with us Martin.
Martin Hofmann
Has liked: 150 times
Been liked: 1958 times
Post by Martin Hofmann »
Thanks Robert,
the next are the much holders for the tools, tracks and head light.
Regards Martin
Martin Hofmann
Here a small update. So many holders and tools..............
Regards Martin
Robert Tanzer
It is with great pleasure that I follow your beautiful build Martin.
One question: Did you make the Fire Extinguisher Tetra and the bracket yourself?
Robert
Martin Hofmann
Hi Robert,
as already written in the mail: thanks for the nice words.
Here comes the next step: priming the mud guards, test fit of the final drive housing and begin to mount the casted drive wheels with the steel sprocket rings. The new challenge is to find a mount that works without a taper lock bush.
Regards Martin
Martin Hofmann
After making a drawing for the flange to hold the sprocket wheel, i tested the design - very good so far.
There are also some modifications on the final drive housings.
Regards Martin
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Awsome build. Perfect model. 8)
Robert Tanzer
Well done Martin
Martin Hofmann
Hi Florian and Robert,
thank you so much for the nice words.
Here come a very small update from the Loctited ball bearings onto the shaft and the modified final drive housings.
Regards Martin
Martin Hofmann
After a very long time, the time has finally come with a new update.
The final drive housing got a small laser cutted sheet inside the housing, because there was a gap so you could see the gear from the out side.
Now it is closed and no dirt can get in.
Regards Martin
Has liked: 153 times
Been liked: 822 times
Very interesting modifications and details. Looking really good.
Graham Ord
Has liked: 4 times
Been liked: 16 times
Post by Graham Ord »
I did more or less the same thing to my P1V before it went to a better owner who could handle the weight.
(see gearbox modification in P1V section)
The whole model was made to Armortek plans and I really enjoyed making it.
Graham
Graham
Robert Tanzer
Hope to see this masterpiece soon.
Well done Martin.
Robert
Martin Hofmann
Hi Bob, Graham and Robert,
thanks for the nice words. Here are the next level of details from the bump stops. Ordered brass plates from a laser cutter, milled the origin bump stops from Armortek and soldered pins into the plates. After this i glued the plates into the holes on the sides. Make some welding seams and glued on a fake screw for the rubber - will follow after painting.
Regards Martin
Marco Peter
Has liked: 1512 times
Been liked: 796 times
Post by Marco Peter »
Master at work...
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
