My Stug conversion
- Has liked: 218 times
- Been liked: 182 times
Hi Guys
Thanks for the kind words I am going to take pictures of the form tool
tomorrow and I will also show the mandril I made to hold the wheels in place.
I am planing to add small lengths of brass tube to make the raised welds
round the small holes.
But that will be done much later in the build.
Hi Guys
As promised some pictures of the wheel tooling.
This is a picture of the holder I made to hold the wheels it has a 4 mm pin
to drive the wheel by one of small holes in the wheel.
This is a picture of the wheel mounted.
This is a top view showing the tool.
This is a view showing the cut shape and tool
This is a close up of the tool.
The tool took a hammering and has bent as I did not harden it fully but it did what it had to,and that is all that matters.This does however show the top and front rake on the tool.
I hope this is of interest
I will now get back to the plate work
- Been liked: 1 time
- Has liked: 126 times
- Been liked: 758 times
- Been liked: 429 times
Hi Derek ... This is real good info thank you ... I will do the same to my wheels . What speed did you turn them ? , slow , med or fast ... Is there still a lot of meat around where the bearing sits ??? . I wonder if one of you guys are going to re-shape the spokes on the idlers so they taper towards the top edge .?? Dale
Hi Dale
I ran the lathe at 70 rpm and used a lot of cutting oil.
Nice and slow does it.
The depth in total in to the bottom of the radius is just 3.0mm.
I used a 10mm dia. end mill for the radius and then blended it in with a file.
So that leaves plenty of meat .
The tool was a bit of 1/8" guage plate and it was hardened by getting it hot to a bright red and then quenching it quickly it was then cleaned up and then tempered slowly to straw colour.
Hi Guys
Well I have been working on the front extensions to the fighting compartment.
These have proved to be a difficut object to make.
However I decided in the end to make them a stand alone units and bolt them to the front face rather than trying to build them on the front face which is at an angle.
The thick plate in the middle is the back plate for the welded mantlet.
I have yet to cut the hole for the gun mounting through the front plate.
the bent side bits were cut half way through and then bent and welded up and then ground smoth again.
There are front armour plates to add to the front of the pods but I will leave them till later when I have the roof done.
I hope you like..
I hope you like..
Hi Guys
I have done some more machine work.
Work on the front panel infills and the welded style mantlet.
These 2 pictures show the infill panels either side of the front extensions also the hole for the gun.
These 2 pictures show the hole bridge piece.
These 2 pictures show the mantlet.
This shows the bridge peice in place.
Hope you like
Hope you like
- Been liked: 177 times
Hi Dale
Sorry its a strictly one off so far some 50 hours of machine time.
I am sorry to say its all been done on manual machines so no program's.
It has been a real interesting project and has really got the grey matter working as there are loads of compound angles to set up and machine
In the truth I like having something unique.
- Been liked: 15 times
Machining
A man after my own heart. I also machined my own P4 from scratch all on a Colchester Student lathe (no digital control) . As you say parts like the front drive wheels really tested the old grey matter.
Graham
- Been liked: 10 times
Hi Guys
Thanks for the kind words I am thinking about the
gun travel as I want the side to side movement as well as elevation
that is what the square in the base plate is for.
In the meantime I am going to start on the roof next I was going to
use steel 2mm thick but I am now going with 2mm alloy I have made card templates and fitted them to the shape.
I think I have managed to get away with 2 parts folded and tack welded.
When I have it sorted I will post pictures.
