Tom's Pershing Build
Tom Miller
Been liked: 344 times
Post by Tom Miller »
Hello Everyone,
I am well into my 7th Armortek build. Seemed like a good time to post a few pictrues of my progress and let other builders know about an issue I had with the front armour casting.
EVO104 front armour casting must fit EVO101 and EVO114 forward hull sides without a step at the joint of the two parts. My casting stuck out about 1/8in on the left side.
This will be a problem later in the build when EVO601 mid mudguard is assembled. EVO616 will also be a problem. The picture shows two black lines I drew to show where ther mudguard goes. My solution was to use an angle grinder to sand off the extra material. I clamped the casting to a table with the offending side facing up and spent about an hour sanding away the step until the casting was even with the side sheet.
Here are a couple progress pics. Next up is the drive case and road wheels.
DaveMacri
Has liked: 13 times
Been liked: 118 times
Re: Tom's Pershing Build
Post by DaveMacri »
Same issue with the 1/8" overage on the left side, I also used an aluminum grinder disk to remove the excess. then put on the weld over that seam. Tom looks like we are about the same point on the build...
Tom Miller
Hi Dave,
Great minds think alike....
Nice job so far. You will have to remove a portion of the weld when you attach the mudguards. You better slow down and get the electronics installed before you seal up the upper portion of the tank.
Carry-on
Tom
Ray Massa
Has liked: 18 times
Been liked: 116 times
Post by Ray Massa »
So this is only necessary because of the mud flaps it seems. Well this should be fun to grind off now that all my suspension pieces are attached. I did not realize that overlap would have any effect on anything.
-Ray
John Burden
Has liked: 5 times
Been liked: 12 times
Post by John Burden »
Tom Miller wrote:
Sun Apr 23, 2023 9:56 pm
Hello Everyone,
Wonderful :(
Nick Chiocchio
Has liked: 41 times
Been liked: 39 times
Post by Nick Chiocchio »
So I ran down to check my tank and it wasn't that bad but it wasn't flush. I used two washers on the bracket that holds the two together and when I retightened the offset was 1.1mm measured with a digital caliper. I think that will be OK. The other side measured 0.79mm. I didn't want to take it apart to grind. It's all primed and painted at this point!
Anyway I'm not sure if this will work for anyone but I thought I would post it. If you try it and it helps let me know, Thanks.
Before the washers
Before the washers
Again, before the washers, not bad
Washers in place
Washers in place
Different view
Different view
Nick C.
Tom Miller
Hi Nick,
I tried that too and got similar results. One concern with that solution is that now the side panel is on an angle outward at the top. That may effect the track alignment as now the front return roller is further out than the rest.
Tom
Tom Miller
Hi Guys,
Thought I would post a couple pics of my progress and offer a suggestion on how the side skirts are attached to the mud guards.
Since pins for the front lugs are not supplied with the kit, I turned up two pins like the ones for the rear tow eye. I also modified the front and rear lift eye's to look more like the prototype. I will add welds where they mount to the hull. Started doing some weathering to get an idea of the look I am after.
I do not want to continue with the upper part of the tank until I get all the electronics installed so I got out the mud guards and skirts. Mounting the mud guards to the chassis is best done before the tracks are mounted otherwise access to the mounting screws will be difficult. Attaching the side skirts is not easy because you must reach up behind the skirt to get the nut in place. With or without the tracks mounted this is not easy. My solution to this problem is to solder the nuts to the back side of the mud guards. I use counter sunk screws to hold the nut in place for soldering. This insures the nut is centered over the hole. I also soldered the 2.5m x 5 screws to the front and rear mud guard so they can be attached or removed with the tracks in place. This is especialy important with the front mud guard so you can have access to the track tension adjuster. Note: the 2.5 button head screws supplied with the kit are stainless and will not solder. I used steel screws left over from another kit.
John Burden
Has liked: 5 times
Thanks Tom
Damon Resch
Has liked: 789 times
Been liked: 69 times
Post by Damon Resch »
Ditto on the thanks, Tom. I appreciate the heads up on some of the build processes that need to be finessed a bit.
Brian Womersley
Has liked: 33 times
Been liked: 28 times
Post by Brian Womersley »
Tom Miller wrote:
Sun May 14, 2023 9:37 pm
Hi Guys,
Hi Tom….Thanks… Great bit of “weathering” you have done so far… I need to learn a few more skills so I can do something like that….. How about a new post of its own on “Weathering advice”
Tom Miller
Hi Guys,
Just discovered another small issue. If you are going to install the lighting option pak Armortek did not drill the hole for the tail light all the way through to the inside of the tank. I used a 9/64th drill and a battery drill to finish the job. There is just enough room to do this with the drive sprocket installed.
I touched up all the screw heads on the drive wheels. Next is to weather them.
Weathering is an aquired skill. I have built models, mostly railroad in many scales all my life. Mig makes all sorts of filters, washes and special effect products that I use along with weathering powders made by Bragdon Enterprises. Buy some of these products and start experimenting. There is no wrong way to do it.
Tom
Dan Fuhrman
Been liked: 7 times
Post by Dan Fuhrman »
Tom,
I noticed you attached your cable hooks to the rear plate assembly without the screws. Did you modify the hooks and weld them to the plate?
Dan
Tom Miller
Hi Dan,
I used the screws. The angle the pic was taken at just hides them.
Tom
DaveMacri
Has liked: 13 times
Post by DaveMacri »
Dan Fuhrman wrote:
Thu May 18, 2023 3:01 am
Tom,
Dan
Mine are on with this technique, I don't have any fasteners show on parts that were welded on the tanks. This can be achieved by countersinking and setting a flat countersunk screw then shaping miliput over the area to blend it all in.
Sorry Tom for steeling you thunder...
