Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
Just lots of machining photos I'm afraid.
Threading by hand with a machine!
Test fit without the locating add on piece
The add on
The add on
Partially parting off the add on
Centering the work piece
Cutting the leveling bolt location slots
Turning the locating spigot
Truing the add on piece
If you want a perfectly true thread this is the only way, just make sure the tail stock is not locked and so can travel with the thread
It all fits nicely
It all fits nicely
I have to go for this standard of detail as Mr Dawe is very fastidious lol
On to the main body detailing of which there's lots
Phil Dawe
Has liked: 755 times
Been liked: 276 times
Post by Phil Dawe »
Worth waiting for! All we need are the clips to hold the front in place. 8)
Kevin Hunter
Has liked: 597 times
Been liked: 142 times
Post by Kevin Hunter »
Outstanding work Phil,
As always, thanks for taking the time to show and explain your work in progress. Watching that huge lump of aluminum gradually being transformed into the searchlight has been……illuminating? :D
Kevin
Thanks Kevin, the body is in fact a little too long right now but I'm reluctant to trim it back untill we are certain as to the thickness of the glass lens that we are going to use.
There's still away to go yet.
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
He blinded me with ... ... his turning skills
It's Grim Up North
Thanks Oliver you make me blush lol. We have now decided on 1 mm lens glass so the main body has now been irreparably sliced.
A searchlight with a Centurion bolted to it!
This is sketchy so tiny cuts are needed
1 mm glass fitted and greasy
That's now to length
Easy maths
Easy maths
I shall use the power socket and socket cap holder as Reference points
The material I'm going to use for the rear stiffening pieces
The U channel needs milling down lots
Phil Dawe
Post by Phil Dawe »
Lovely Jubbly! :D
The searchlight detail starts now.
This work is almost like watch making
The fit must be as near to perfection as possible, the rivets we are using have a head size of 1. 3 mm
Handles cut and bent up ready
I've just tacked the handles in place to check the fit and look
Gary Richardson
Has liked: 727 times
Been liked: 1673 times
Post by Gary Richardson »
Hi Phil
That is a brilliant bit of machining on the searchlight. Top notch.
Gary
More watch making but we are getting there, we are referring to the piece as " the 1K searchlight" and that's not a reference to weight!
I've only broke one 1 mm drill bit.
All keyed ready for paint.
A bit of grey primer to check the finish.
Damon Resch
Has liked: 738 times
Been liked: 61 times
Post by Damon Resch »
Such a pleasure to see the skill and craftsmanship you bring to your builds, Phil. Thank you for sharing your work, a true Masters Class on so many levels.
This level of detail is ridiculous.
Air brush parts are great
Very fiddly work, about as tiny as I'm comfortable with
A waste , not really as this donor kit saves lots of machine time
Air brush brass parts are just the job
The pin becomes the center contact
That's 1 mm brass tube
Using the air brush fitting
This will be the socket blanking cap holder
And it's all functinal
I'm relying on the earth through the outer socket cap, now to the bulb and it's wiring.
After much farting around.....we have light. As I can't be bothered wrestling with the predictive text tonight use your imagination :D
They say a picture says a thousand words.
I must remember to fit the little pcb, I guess the pcb is for over voltage protection?
I think the searchlight will have its own switched power supply
Has liked: 762 times
Been liked: 1739 times
I'm a bit lost Phil.
What's being used in the searchlight? LED or bulb?
Phil Dawe
Post by Phil Dawe »
That bulb looks the part Phil. It would be a shame to put an IR filter in front of it 8)
