Hi all
Started the build and the 1st question of many, hopefully you will not get fed up with more than likely many questions.
Page 1
Q1, The front Glacia plate bow machine gun, should this be glued flush with the rear of the ball mount, or flush with the front of the ball?
Q 2, Should all retaining screws be thread locked?
Thank you for any advice
Panther Build 2022 68
- Has liked: 4 times
- Been liked: 11 times
- Brian Ostlind
- Has liked: 957 times
- Been liked: 2040 times
Re: Panther Build 2022 68
Hi Steve I would push the machine gun into the ball until the thick part is inserted and leave it there.
Thread lock with blue is good I’ve had lots of screws come loose without it. That being said some areas are more critical than others so I don’t use it on every screw.
Hi Brian, enjoying your YouTube channel, need you to do a full detailed Panther build not missing out on anything then I will not feel out of my depth
- Brian Ostlind
