Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
Heavy work in 1/6 scale
Always looks a mess at this stage....
and it does
and it does
Flatening
Flatening
Very awkward to get in there
Ready for the plate to be cut
Fitting the extension piece, file and fit file and fit
Fitted and ready for soldering
Old sparky warming up
The rear that's against the turret will need some gentle tidying, I can just about get a weld bead using a filler rod but there's no point.
Getting the bottom plate to fit nicely
Tacking the corners so it will not move whilst old sparky does his business
You can scrape the excess solder off but the more you remove the weaker it will become, this is the out of sight underneath section so only needs a gentle tidy up
After a quick dusting of red oxide
I'm happy with that
I'm happy with that
Phil Dawe
Has liked: 755 times
Been liked: 276 times
Post by Phil Dawe »
The long turret bin has a three compartment housing inside at the left hand end which Stephen White included in his Aussie Cent detailing. Does anyone know what was contained in these compartments? 8)
Kevin Hunter
Has liked: 597 times
Been liked: 142 times
Post by Kevin Hunter »
Phil(s)
I have a couple of books with so called “stowage diagrams”. One such drawing, albeit purporting to be for a Mk 2, suggests the “long bin” held 3 thermos flasks, in addition to items such as blankets, groundsheets and greatcoats. I will email you a snap.
I came across a similar diagram for a Mk 7. The writing is unclear but the long bin stowage is similar to above. In this diagram it’s hard to see whether there were 3 or 5 “jars, thermos 1 qt”. It doesn’t seem logical that the equipment level would increase from 3 to 5 with same crew numbers.
Based on these diagrams, at least, it would appear the 3 receptacles you refer to might have held 2 pint thermos flasks.
Kevin
Michael Cecil
Has liked: 73 times
Been liked: 109 times
Post by Michael Cecil »
User handbook for Tank, Medium Gun, Centurion Mk 3,5 and 6 (1953) with amendments to 1965, shows the long bin containing:
12 blankets; 4 groundsheets, 4 greatcoats, and 3 'Jars, Thermos, 1qt'.
The earlier handbook for the Marks 1 to 3 lists the same contents.
Taking Kevin's post into account, it appears the War Office standardised listed 'by the book' stowage in that bin on the Centurion tank was near-constant through the various marks of Centurion tank.
Mike
Mark Heaps
Has liked: 269 times
Been liked: 324 times
Post by Mark Heaps »
Michael Cecil wrote:
Fri Jan 13, 2023 5:33 pm
That 'strange mounty thing' is the coolant header tank and filling point for the sight elevation control arm cooling system (or whatever its correct nomenclature is!). The elevation bracket pivots from the turret roof and is connected to the armament by a link bar. The link bar is a tube which is connected via piping to the coolant reservoir. It is to keep expansion/contraction of the link rod to a minimum due to variations in temperature and hence, minimise alterations to the armament-range gear relationship. Only applicable to tanks equipped with the RG.
Mike
Only disagree with one minor point "Only applicable to tanks equipped with the RG"
May have only been introduced and fitted to Centurions equipped with the RMG so comment is relevant and accurate for Centurion.
The temperature compensated link bar became more important later on in Chieftain when the RMG was phased out and a laser range-finder in the sight was introduced. With the RMG, the gunner could observe splash and correct Point Of Aim if needed and then confirm by firing the RMG again before firing Main Armament. With the absence of an RMG, a correct and constant gun / sight alignment becomes more important to ensure a first round hit with the Main Armament.
In 1985/86 the RMG electrical firing circuit was still being taught in REME although most Chieftains by then no longer had the RMG, having been fitted with the TLS ( Tank Laser Sight ). I can remember one cartoon on the classroom wall instructing us what to do if we could not get the RMG working or did not have a tank with us. Send the Recovery Mechanic out armed with a track pin to bash 3 times on the hull of the enemy tank, the crew would then immediately bail out and run to the rear expecting a 120mm round coming in.
As an ECE, my job with the link bar was to ensure the electrical pump worked, crew were responsible for monitoring and topping up fluid level, everything else was the responsibility of the Gunnfitter. If RMG was fitted, I was also responsible to ensure the electrical firing circuits for it worked.
Mark Heaps
Sun Feb 26, 2023 1:28 am
Taking Kevin's post into account, it appears the listed stowage in that bin was near-constant through the various marks of Centurion.
Mike
Maybe Stephen White can give some input here. With stowage, there are various options. As per documentation for hand over / take over, optimised for crew, and optimised for regiment, ( differed from the standard layout, not maybe as good for the crew, but allowed any crew member from the same regiment could jump from one tank to another and find what he needed )
Thanks for the replies guys!
The long bin is getting there, lots done despite an scheduled appointment with a tree surgeon who has quoted me £600 a day and that's for just him, I'm in the wrong business!
The new bin catches are nice
I've fabricated the radius piece that was designed to clear the turret cupola protrusion
Squaring away
Squaring away
Milling down
Milling down
Those 90° cut outs again, so easy with the mill
Gussets fitted
Gussets fitted
Bolting the stiffeners in position , there are around 50 nut and bolts sets in the long bin.
I presume the three sectioned stowage piece fitted to the left hand side of the long bin is for those thermos flasks?
Would anyone have pics of the thermos perchance? A 3d printed set would look great stowed in the bin.
Careful mounting of the stiffeners, if they are just slightly out they will look pants
Here's a tip, make yourself a drill bit extension to get to those hard to reach places
Bolts everywhere
Bolts everywhere
Here's a tip, hold one side of the Gillbows or snips in the vice to help get a nice straight cut
Best use a square to check before you bend the work piece
Tricky to make this piece but worth the effort
The stowage piece lives here
Nearly done with the internal stowage piece, it's all now soft soldered together
Marking through ready to drill and tap the mounts
I'm now ready to temporary mount the bin , then off it comes again for the angle iron support for the bottom section
Getting there with the coffin bin.
Off we go
Off we go
Setting the stand off distances
Milling down the equal angle pieces
Example of the coffin bin
Bottom brackets made
How to hold those drill bits less than 2 mm
Angle iron bottom supports bolted in place
Same as the small bins just more of it
A few more rivet bolts to make and then the soldered furniture to fit
Just call me Mr solder.
Possibly WW11 issuse but still in service for our Centurion?
FYC M FE GB Thermos Flask 1.jpeg (45.84 KiB) Viewed 884 times
Crew thermos for hot drinks or hot food, is this the one for the big bin?
One man thermos insulated pouch
Just about all done in there just the bulge weld bead to add in milliput
Not my favorite job but it goes with the territory
The latches must be perfectly aligned
The original bin fixing holes now filled this side
All done with soft solder
Using a scrapper to remove the unwanted solder is the correct method
A dusting of red oxide to check the finish
Nothing standing out finish wise so I'm happy to now move into the camo net strap fixings and the tricky webbing
Well but for some minor snagging and the webbing strapping these bins are done, they can sit over the weekend to cure the paint.
I've removed the light dusting of red oxide prior to soldering the catches and the strap anchors
Webbing straps cut and ready
I decided to remove the short bins paint back to the next fold rather than flattening back
Cleaned up and rubbed down
A good couple of applications of primer before some top coat
If you can't get a good finish with the Tamiya TS range of paint your in the wrong hobby
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
Hello Phil,
as always very informative, entertaining and above all an excellent build.
It's Grim Up North
I shall try again lol. The webbing straps are now fitted to the long bin.
I'm using Armorpax superb strap ends and buckles
Off we go
Off we go
Tricky work getting all three straps the same length and aligned
There's a lot going on with that long bin
All done except for the fire extinguishers which should be here any day now
Lots done although it doesn't look like it.
I have to start thinking about the turret basket.
Armorpax extinguishers
Secret belt and braces mounts for the stowage bins
Fire extinguisher stowage reference photo
Reference photo
Reference photo
Umm some work required here
Best get the don 10 real out the way now, and tidy this area
The 2 the down fittings bent up ready
Lots of top coat to give a nice slippery surface for the decals to slide
I'm using Rolls Royce wheel fittings for this piece
Who would of thought there was so much detail in this tiny piece
A tip , trim the decals down or they won't fit easily
Now I should be able to modify the kit mount to fit
Another afternoon in wooly woollards workshop.
Adapting the kit spindle to fit , this involves turing it down and making an extension piece
Paint stripping
Paint stripping
I'm working on the other jobs to do as each stage of the fire extinguishers has time to cure
Use a reference to get the decals mounted correctly
Nearly done with these , if you rush each assembly stage you will mess these up
See the folded in winding handle?
Cutting the groove
Cutting the groove
A tip, super glue the small piece in place before you drill, then drill as one and it will be a perfect fit, then use some heat to remove the cyno and pin the joint
I'm happy with the don 10 spindle mount
Working latch works
Working latch works
Fire extinguisher mounted in the most awkward place but it is protected in there.
That weld bead on the lifting eye needs replacing, it's rough and the weld vee is upside down.
