'2019' King Tiger - Fitting the Mantlet.
Tom Wittstock
Been liked: 18 times
Post by Tom Wittstock »
All, question regarding the fitting of the Mantlet.........the instruction tell me to use loctite......Will this work and/or should I drill into the mantlet and insert a set screw? Any pictures will be appreciated .......
Thanks Tom Wittstock
Michael Allen
Has liked: 1040 times
Been liked: 79 times
Re: '2019' King Tiger - Fitting the Mantlet.
Post by Michael Allen »
Tom
Sorry but I cannot help you at all with this but I have a small favour to ask.
My kit is missing part No.CK0770, can you send me a picture of it fitted as I have no idea what it looks like.
Many thanks
Tom Wittstock
Michael, don't have that part?
Charles A Stewart
Has liked: 512 times
Been liked: 933 times
Post by Charles A Stewart »
Evening all.
Part CK0770:-
Aluminum, 195mm X 22mm, bored out and thread at both ends, unfortunately I don't know the thread size.
This part may have been with the option pack as I found it unbagged in the box of bits which is my KT presently. Unless test fitted all parts are still bagged.
Hope this helps.
Charles
Michael Allen
Many thanks
That’s a big help
I’ll have another look as the previous owner could not start the build at all but did put a few parts of the gun together
Bet its in the their……
Yes it is
Great stuff
One issue resolved
Michael Allen
I think it’s this
Charles A Stewart
Pleased to have been of service.
Charles
Tom Wittstock
Can we get back to the main subject of this topic the mantlet.......Any help out there on what the best method of fitting the mantel would be....
Thanks again...Tom
DaveMacri
Has liked: 13 times
Been liked: 118 times
Post by DaveMacri »
sent u a PM on FB messenger
Michael Allen
Tom
Huge apologies, didn’t mean to hijack your post.
Got carried away.
Good luck with your issue.
Mick
Been liked: 3704 times
Tom Wittstock wrote:
Sun Feb 05, 2023 5:24 pm
In the factory we have loctited CK0413 onto CK0412. It has many hours of running on it and we have no issues.
If you want to go down the route of drilling and tapping, this should not be an issue but we don't see any need for it.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Tom.
As Armortek replied, “ loctite is sufficient “ but if you ever see the need to disassemble the gun mounting then drilling and taping for a M4 grub screw is the way to go.
Hope this helps
Tom Wittstock
Thanks everyone for your help..... :D
