Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
It doesn't look like I've done much but what I did took all afternoon!
Easy does it as this is delicate work
Turning down already small counter sink screws
This thinner piece (of the same shape) sits behind the thicker outer part
Good ol chain drilling
My hobby this
My hobby this
One glass block for the periscope and one for the cover needed
Functional
Functional
I have found some smaller rivets so I shall swap those out on the hinge
I'm nearly ready for the wing nut clamps , wiper blade , sockets ,wiring and the two glass blocks, oh and a few more fixings to the rear.
Michael Cecil
Has liked: 73 times
Been liked: 109 times
Post by Michael Cecil »
.... and the wiper will wipe and the squirter will squirt, right, Mr Wollard?? :wink: :wink: :D
Hmmmm maybe Michael lol. Don't tempt Mr Dawe or may ask me to do just that!
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Post by Oliver Brüninghaus »
OMG a lot of wonderful small parts have already been created here in the first days of the new year.
And the parts are getting more and more delicate. If it continues like this, we will be surprised with modeled dust particles in 1/6 at the end ... ...
Amazing!
It's Grim Up North
Phil Dawe
Has liked: 755 times
Been liked: 276 times
Post by Phil Dawe »
Phil Woollard wrote:
Fri Jan 20, 2023 7:13 pm
Phil, I thought we had already had a conversation about having a working wiper?
I will see what I can do!
Has liked: 1023 times
Been liked: 2093 times
Go for it Phil, you can do it if anyone can.....
The cover wing nut brackets all done and the cables cut and fitted
The wiper arm shafts positions but only one is used
About as fiddly as I'm comfortable with, the cable mounts turned from 12ba bolts
One wing nut brackets done
The cover is still functional with the cables added
Tiny brackets
Tiny brackets
Soft solder again for these brackets
The wing nut slots
The wing nut slots
I'm not going to fit the NATO stock number yellow sleeves just yet as there's painting to do
I've made a start on the wiper arm
David Battson
Has liked: 109 times
Been liked: 232 times
Post by David Battson »
Phil,
A really good reference record and 'how to' on the fabrication work. Nice to see all these details being put together with good old fashioned real metal rather than 3D printing. Details like the loaders hatch are similar on Chieftain, so this is of great interest for the future.
Phil Dawe
Post by Phil Dawe »
Lovely work Phil, your updates on this thread always put a smile on my face. I am glad to see other members are benefiting from your methodology during the upgrade/detailing. :D
Just about finished the gunners sight!
There are twelve parts to make up the wiper, that's crazy.
Acrylic glass for the cover
This is the mirror dimension boss.
Masking up
Masking up
Phil Dawe
Post by Phil Dawe »
A work of Art, Phil. I shall take your glass measurements to the glass merchants tomorrow. 8)
Getting ready for the big turret roof weld, which means getting all the little jobs out the way first
Bonding and bolting the gunners sight
Marking out the conduit runs, some "p" clips will need making
I have cut the conduit material long for now, I shall fix later
I do like the Tamiya TS range
Bonding and bolting the roof fixings, the roof needs to be removable so the big weld must be attached to the turret but not to the roof so some trickery is called for
Checking the finish
Checking the finish
Not my favorite job at all but it must be done
Nice to see a bit of top coat
The big weld is now done.
Painting the surface that I don't want to be bonded with a light oil.
As it's very cold in the workshop ( until the heater has kicked in) I use a blow lamp to warm the mass.
I've lifted the turret roof out very carefully so not to deform the weld bead.
Tomorrow I will check the fit, I will then run cyno around the beads contact area with the turret, this will ensure that it stays in place.
I'm happy with that
I'm happy with that
I've placed some silver sticky back foil behind the glass of the loaders sight
Difficult to get this weld to look as rough as the real thing
Moving on with the turret work.
Bonding the the now cured milliput weld bead.
Turning the conduit fittings, that's a 2 mm hole in a 2.5 mm rod
I'm very happy with the weld bead
Some times the vice helps with this job
Tricky job but just take your time
The conduit must fit around the stowage bins
Milling the P clips down to size
This brass tube bends really well, 12 ba fixings, that 12ba tap is top quality boss!
Using the correct diameter drill bit as a mandrel to make the P clips
Flexible piece
Flexible piece
You can clearly see the flexible piece on the end of the conduit
I think we may need to make new smoke discharges , certainly the brackets
A light dusting of NATO green to check the finish
