Mr Dawe's Centurion.
- Has liked: 2259 times
- Been liked: 7147 times
Re: Mr Dawe's Centurion.
Lots done and lots to do.
Nearly there with the loaders hatch and associated.
And for the patient purists, the loaders hatch but for top coat is finished.
- Does anyone know of an stl file of the Morris donkey engine, any scale is ok as I can resize. Even a very similar engine would be ok as I can modify to suit?
- OIP (12).jpeg (43.75 KiB) Viewed 1204 times
More of those armour pieces
- Steve Lewington
- Has liked: 8466 times
- Been liked: 277 times
Outstanding work phil always a pleasure to see.
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
No respite.
No forgiveness.
- Has liked: 597 times
- Been liked: 142 times
Here's another for you Kevin.
- Has liked: 73 times
- Been liked: 109 times
That 'strange mounty thing' is the coolant header tank and filling point for the sight elevation control arm cooling system (or whatever its correct nomenclature is!). The elevation bracket pivots from the turret roof and is connected to the armament by a link bar. The link bar is a tube which is connected via piping to the coolant reservoir. It is to keep expansion/contraction of the link rod to a minimum due to variations in temperature and hence, minimise alterations to the armament-range gear relationship. Only applicable to Centurion tanks equipped with the RG.
Mike
Mike
Thanks Michael, getting along with the gunners scope.
Lots done to the sight.
A bit more done.
- Chang
- Has liked: 15804 times
- Been liked: 424 times
...1/4 scale Panther...
Sounds interesting.
Sounds interesting.
