Removing grub screws, best method.
Gian Marco Menozzi
Has liked: 14 times
Been liked: 324 times
Re: Removing grub screws, best method.
Post by Gian Marco Menozzi »
HI,
where I can not mount either hex bolts or Allen bolts,
I use this type of grain,
https://www.ebay.it/itm/For-RC-Axial-SS ... 2d012adaf1
which however needs a hole on the pin that must stop,
and I do not use threadlocker.
Marco
yves mouton
Been liked: 567 times
Post by yves mouton »
Hello,
For easy maintenance i flatten all my grub screws ( strong fit on the flat surface of the torsion bars ) on the torsion bars.
So if you need maintenance on the torsion bars you can take them out easy trough the copper bushings.
I did this on all my tanks and halftrack
best regards Yves
Gary Richardson
Has liked: 738 times
Been liked: 1701 times
Post by Gary Richardson »
Adrian Harris wrote:
Wed Aug 10, 2022 9:31 am
This may be a little late but I have found that stuck hex head bolts snap much more easily than HT cap head ones.
Hi Adrian
I have found out you can get half head height cap bolts which I may go for instead of hex heads. The main problem is the threaded holes seem to end up facing the hull floor once the axles are installed so there is limited clearance. When the suspension shafts are fully screwed into the suspension arms
and they are installed as per the instructions that's how they end up, to undo them half a turn leaves the assembly loose. Anyway I have spring roll pinned them all now so they are very secure :D
Gary
