Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7147 times
Re: Mr Dawe's Centurion.
Lots done.
Lots of work to be done at this end.
Lowering the turret turn fixings out of sight
Must not forget these.
Old holes filled in and new ones drilled
Rubbing flat
Rubbing flat
We really need the dimensions of the fuel filler caps
I'm very happy with the look
Don't know why this is up there
Drilling and tapping in situ
That's better
That's better
A quick look see
A quick look see
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
I am hoping Stephen W will help us with the dimensions of the fillers :D
Has liked: 1023 times
Been liked: 2093 times
Here you go.
Many thanks Stephen.
Milling away the sump today .
Magneto and water pump housing
It just won't fit unless I remove a big chunk
Phil Dawe
Post by Phil Dawe »
Thanks Stephen, your help is always invaluable !
Some parts on order so I'm cracking on with the drivers hatch.
We can't use these
We can't use these
All dismantled, the hatch sections can be checked against the 1/35 kit parts and used as templates for the outline dimensions
Rolled armour effect completed but hard to make out in this photo
I'm using spare parts from previous builds , so long as there's plenty of material to machine away I'm happy, it beats waiting on stock to arrive by post. That's a KT escape hatch on the left and possibly an interior part from a 251 or 7 kit.
So I shall be standing by this machine for a few afternoons.
I have lots of farming chores to do this time of the year but trying to get the afternoons in the workshop, it just means very early starts.
Easy math for the hinges, 4mm by 4mm by 4mm by 4mm by 4mm by 6mm high.
Hinges
Hinges
10mm thick with lots to come off and an underside to detail to.
Coming on that's both parts roughed out.
Lots of milling
Lots of milling
That's the 1/35 hatches for scale.
Moving on with the drivers hatch
The last of the outline cuts.
Tiny parts for the hatch furniture
This is the gap that will need addressing now the hatch profile  is correct
The water pump
The water pump
It's coming on.
It's coming on.
Just machining photos or photos of machining, the drivers hatch continued.
Sometimes there's so much swarf you just can't see what you are cutting and one slip could mean making a whole new part, the dro helps no end.
I don't have a boring tool so I use the rotary chuck which gives me any size I require
It's an awkward shape to hold
I don't think we can use these periscope covers
It's a big hole
It's a big hole
Almost ready to start on the periscopes
Phil Dawe
Post by Phil Dawe »
That's a significant amount of machining you have had to do Phil!
And more machining of the periscope rotation mount to.
My cut off saw has never cut square!
Mr D do you want square corners in the brass opening?
It's always advisable to center drill whilst in the lathe, I can then easily pick up that center in the rotary Chuck on the mill.
Another 10 tins of paint arrived, that may be enough now but I doubt it
Aluminium stock arrived in the post
The blanks are now ready
I find it's belt and braces to mark out the work even though you will be relying on the dro and your maths during machining
Note my unusual work piece holding spacers
Long way to go yet, these are just the top sections.
Back on the cent.
I'm at the height limit on the mill so the cutter must be moved up and down in the collet.
Always blueing before machining
Patience is required
Nice combination of machining and hand fitting
Machining the smaller details
Loads more to do but I'm getting there
Phil Dawe
Post by Phil Dawe »
Lovely work Phil, I presume the temperature in the workshop is now at a bearable level!
Cheers Phil much appreciated, and yes it's just hot now and not very hot!
Lots done just in a very small way.
From Armorpax
From Armorpax
Pivot points
Pivot points
They will swivel back and forth Mr D!
Milling down Armorpax periscope Assemblies , these are tiger 1 but not for long
There so much to do under the hatch, in fact as much as above
Simple but effective securing method using a grub screw
Using the parting off tool to create the retaining slot for the periscope post.
I will need to fill that threaded slot once the grub screw is all the way home.
A job for tomorrow afternoon, make these shrouds fit.
