Mr Dawe's Centurion.
Michael Cecil
Has liked: 73 times
Been liked: 109 times
Re: Mr Dawe's Centurion.
Post by Michael Cecil »
Very interesting thread and great workmanship.
I keep seeing the reference book you are using, so being a something of a collector of Centurion-related literature, purchased a copy.
My main comment to anyone using this book: be very careful about the authors' interpretation of the images. They appear to know very little about the subject matter. I'm still tossing up whether I'll purchase Part 2, but I suppose the images will be worth it.
Mike
Has liked: 2259 times
Been liked: 7147 times
Plodding on through the hatches detailing and there's a lot of it inside and out.
Two pairs of glasses are necessary for the 1mm drill bit pegs
Cheap small drill bits used as pegs.
The mill is so useful, it's very quick and very accurate, I don't need to use my brain much.
Milliput
Milliput
Almost done with rear outer hatch detail.
I'm looking forward to starting work on the forward hatch vents.
Phil I have ordered some more 8x8 mm rubber block.
Metres of milliput weld beads
Hinge bolt cosmetic detail started
Hinge bolt detail complete, these really are non functional
And now onto the actual engine hatches.
I'm using plasticard to build up the layers of construction, it's very much like adding Armorpax parts
Getting there but more detail required then onto the weld beads.
One of these is a must for detailing
I want to use the kit parts where ever possible
The 8 mm rubber sheet arrived , nice sulphury smell to like rubber used to have.
I have to make this inlet manifold by hand, that's a work of art that Stephen has there!
It's very heavy and can be shaped as required
It's cuts beautifully
I have to allow for all those bolt heads, I shall try a red hot piece of small bar to burn the clearance holes.
Has liked: 1023 times
Been liked: 2093 times
Lovely work Phil, another masterpiece. One piece of detail to note on the engine decks. In order to prevent enemy infantry (and the tank crew) opening the decks too easily, they were made to interlock. You can see how I tackled it in these pics. Like a lot of things, it's detail you don't see externally, so not really needed but a nice bit of authenticity. Now, it's a pain when it comes to fitting the replica Meteor.
Thanks for the advice Stephen, I did notice the interlockness and I think I can do something to replicate it.
Some more detailing done whilst melting in the workshop.
Dressing the add ons so they interlock
Very nice brass stock from these guys if a little expensive
You have to watch the small hole detailing as the configuration is subtly different, some have four some have three. Don't ask me what these are for as I have no idea!
I'm pleased with the look, long way to go yet. Thanks Vince.
More rear deck work, I've decided to cut and fit the rubber buffers today.
I'm very happy with these.
My little guillotine has been a God send
I found that drilling the clearance holes was easier than a hot rod.
I need to get these near perfect for the boss!
This rubber can be worked quite nicely
Nearly there
Nearly there
Lots done to the hatches
Some of the hatch detail parts can be printed, thanks Vince
Bare bones
Bare bones
Reference photo
Reference photo
Some printed parts to speed things up a little
Cover strips cut ready
I need to take a millimeter of this face to allow for the cover
Reference photo
Reference photo
Hatch lock blanks
Hatch lock blanks
There's ten of these double sided inserts to make
Must not forget the radiator hatch locks
Almost done one, just the bottom cover to print to finish this off
Steve Norris
Has liked: 8 times
Been liked: 688 times
Post by Steve Norris »
Going to town on this one !
Great detail, I don’t see anyway to improve what you have done.
Keep up the posts , it’s a great inspiration.
I'm now very close to completing the marathon engine hatch detailing, I think number one is now done but then I see a locking aperture that needs drilling.
The printed underside cover, thanks Vince.
The 1mm coming off to allow for the 1mm cover. You can see how robustly the add ons are bonded, the cutter passes over them without a problem.
I've changed out the socket heads for reduced head bolts, this is a necessary compromise as we can't afford the hinge fixing to loosen over time.
The inside face will seldom be seen but if I can pull off the meteor engine and compartment this work will be worth the effort.
Nearly complete just a few more reduced heads and about .5mtr of very fiddly weld beads then I can move on.
What would I do without that printer.
Assembling the last two hatches inner detail.
This late afternoon sun is a pain.
Finally done, I hope you like them boss?
All the tiny welds now complete
And now for the NATO green
Inside
Inside
That's a lot of work. Outside.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
Top job, Phil! 8)
