David's carrier build.
- Has liked: 2267 times
- Been liked: 7152 times
Re: David's carrier build.
Spent the morning putting the engine together.
Mike Tulls beautiful four cylinder early uc engine fully functional with gearbox JC.
Rivet head bolts size 7ba x 1/2" would be good, purchased in bags in of 500, we don't expect to use that many for one build, you will also need say 50 with slot heads too John.
- IMG_0706smal.JPG (202.28 KiB) Viewed 2421 times
- IMG_0715smal.JPG (179.21 KiB) Viewed 2421 times
- IMG_0704smal.JPG (175.84 KiB) Viewed 2421 times
- Has liked: 116 times
- Been liked: 1106 times
Hi John,
I used 8ba unslotted and slotted by 1/4 with 1 size smaller nuts.
Dave
Dave
www.armorpax.net
No I didn't, I used 7ba but they were 1/4, less to trim off where required. I am using 8ba now for some reason.................must be the heat.
Dave
Dave
www.armorpax.net
Mike has just sent me the exhaust routes, apparently they were constantly being damaged so as an expedient angle iron was run along side to offer some protection!
That makes my job a little easier as they can just butt up to the hull floor unless Dave wants the full system?
- rv35011d26.jpg (22.82 KiB) Viewed 2415 times
- rv35011d31.jpg (33.81 KiB) Viewed 2415 times
- Has liked: 467 times
- Been liked: 407 times
- Has liked: 87 times
- Been liked: 62 times
Happy with the plan for the exhaust. Its all starting to come together beautifully.
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1073 times
I have to say, that engine is quite the show piece. Outstanding...
Just a few hours done this morning as it's just to oppressive in the shop right now.
I'm changing the engine pulley configuration to suit the universal carrier
- Has liked: 551 times
- Been liked: 409 times
I'm glad you guys are enjoying my builds.
- The small 12v motor from eBay was going to fail, so I have used one of the vsh video motors which are great quality, don't get hot and are silent with decent bearings. If you look closely you can see the join in the outer casing of the generator which needed lengthening about 15mm to look convincing
A working fan on a fantastic motor and its working to boot. That's really cool and is probably the only thing that is in this weather. Phew.
- Been liked: 1789 times
Thank you both for the info on the round heads. Dave Dibb's UC looks wonderful and this one's becoming a star attraction.
Super job guys.
That's one mighty fine looking IC motor of Mike Tulls. (But not envious)
Sadly the only thing I'll be animating other than the standard UC R/C is the driver. With a Jason "The monk" Statham twisty steering head.
[attachment=0]The Monk.jpg[/attachm ent]
Super job guys.
- The Monk.jpg (146.22 KiB) Viewed 2197 times
Nothing very exciting to report but very important all the same, rivets, maybe the rear light that's a little exciting.
Last edited by Phil Woollard on Tue Jul 19, 2022 6:30 pm, edited 2 times in total.
Looking good. Keep it with the four crew steps.
Hope you've got something to keep you cool there beyond the fan on the motor.
