David's carrier build.
David Merritt
Been liked: 48 times
Re: David's carrier build.
Post by David Merritt »
Hi Phil, I have had no problems with the tracks on the UC apart from throwing then off the front idler wheel when execution tight turns at speed in reverse. I am running a twin motor/gearbox configuration which will revise one of these tracks when making tight turns. Tuning the transmitter and reciver to remove the reversing of the track when turning has eliminated this problem.
When measuring the inside of the tracks when curved to the same radius it takes when on the sprocket the pitch of the opening that the teeth engage in is appropriately 6.3mm so the pitch of the sprocket is probably correct for the tracks.
I am also running the UC with the full number of track segments in each track as per the build instructions with no problems.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi Phil,
Mine ran much better on the pins and seems to engage on the sprocket OK. Now I have the 2 motors in going to be able to drive it more so will keep you posted. Might also be mine have bedded in too.
Might be worth running it in before you mod?
Dave
www.armorpax.net
Has liked: 2267 times
Been liked: 7152 times
One track ready and running.
Journal filing x 162.
Fitting the pin nuts is a bugger and each one needs thread lock.
With 12 volts it sure does belt round at some insane speed!
The finished look outweighs the fiddliness :-)
Dave
www.armorpax.net
It is a good look!
Dave Green
Has liked: 87 times
Been liked: 62 times
Post by Dave Green »
Looking very impressive
I do like the little carrier Dave, I will be happier when it's on two tracks. The tracks are very slack with 162 links and when it's fully loaded it will sit lower and so a couple of links will need removing, there's no slip of the sprocket without any load so fingers crossed we are getting there, the brakes work using just finger pressure on the linkage! 8)
Dennis Jones
Has liked: 10 times
Been liked: 223 times
Post by Dennis Jones »
Down to 154 links on mine. Apparently they were known for throwing tracks.
Dennis.
Has liked: 1420 times
Been liked: 1595 times
No need to strive for total realism then :lol:
I must have a longer carrier................163 each side on mine :-)
www.armorpax.net
Your receiver has arrived safely Dave along with a pair of metal servo savers.
Dave Green
Has liked: 87 times
Great stuff. More bolts on the way and transmitter too!
David Merritt
Hi Phil,
You have just made me take the tracks of my UC and check that I have the correct number of track segments making up the tracks as I don’t have the same amount of slack in the tracks.
I have the correct number of segments in the track and to make the final connection I have to have the open links on the sprocket and the wheels on the ground as it is a tight pull to close the gap.
From the photo with the track in the air the single wheel is held a long way down by the springs which I have to pull up to close off the tracks.
Side view of UC supported so wheels are clear of the ground
Side view of UC showing tracks fitted
David what track pins are you using?
Hi David,
Mine is very similar to yours and initially took a bit of pulling together. They have stretched a fraction since but no where near the slack of Phils :-)
Dave
www.armorpax.net
