Jagdtiger No40 build.
Paul Sparkes
Has liked: 84 times
Been liked: 217 times
Re: Jagdtiger No40 build.
Post by Paul Sparkes »
Update time, after playing lots with recoil and servo's I have finally given up and gone with CO2. I couldnt get the right return movement with the heavy barrel.
And the linear servo is working great for elevation, the slew is waiting for a speed controller but works just the same as elevation.
Moving MG was next on the list and with a little plate and a servo this was achieved.
222 scout car
Has liked: 762 times
Been liked: 1738 times
Awesome Paul. To recharge the CO2 bottle, do you have to take it out of the tank?
Paul Sparkes
Has liked: 84 times
Vince Cutajar wrote:
Sun Jun 05, 2022 2:20 pm
Vince, this is still the prototype, I’m looking into a tank that can be filled, but even so the welding bottle is easy to change on the Jag
222 scout car
Paul Sparkes
Has liked: 84 times
Pretty happy with how all this is working, just needs a little more tidying up one day.
In the picture you can see audio amplifier top right corner, regulators for CO2 bottom right, bottom middle is the 24v lifepo4 battery, then welding bottle on the left side. Middle top is the main gun elevation, co2 recoil and slew servo.
MK2 of the gun elevation now has a 12v linear actuator to replace the linear servo which broke the top off at a show, the actuator is controlled with a small 12v esc from Beier.
CO2 system comprising of 600g disposable welding gas bottle, piped to the duel regulators, the first to show bottle pressure and the output set at 40 psi for the main gun Recoil, the second is a lower pressure 5psi used for gun smoke. Both systems are solenoid activated by the Beier Usm rc3.
222 scout car
Paul Sparkes
Has liked: 84 times
With a background in sound and AV a high quality sound was always high on the list of priorities.
With space available 4 x 4” Jbl coaxial speakers were used and 1 x 8” Jbl subwoofer.
Mdf boxes were made to exact fit the space.
They sit above the electrical system of fuses relays etc (no Armortek red boxes are used on my build)
Power is supplied by a 4x100w 24v truck amplifier from Ampire in Germany
Plenty of controls
222 scout car
Paul Sparkes
Has liked: 84 times
Started work on some hatch animation, turned out good so far, will mod servo to give some extra rotation.
[media] [/media]
222 scout car
yves mouton
Been liked: 563 times
Post by yves mouton »
Hello,
Nice job Paul on the hatches 8)
Also your recoil system is awesome 8)
Best regards Yves
Paul Sparkes
Has liked: 84 times
Been playing with gun smoke again, I wasn’t happy with the projection or amount of smoke.
Much happier now, just some timings to adjust.
Thinking about offering a gun smoke solution to other owners if there is interest, but I need to iron out some triggering problems with benedini based tanks.
222 scout car
Gerhard Michel
Has liked: 3 times
Been liked: 617 times
Post by Gerhard Michel »
Hi Paul,
the first suitable gun firing and smoke system I have seen. Congratulations!
Gerhard
Damon Resch
Has liked: 736 times
Been liked: 61 times
Post by Damon Resch »
Looks amazing, if you decide to offer a system, count me in. :D
Gary Rafferty
Has liked: 252 times
Been liked: 442 times
Post by Gary Rafferty »
That looks superb, I think a lot of people would be interested me included.
Gary
yves mouton
Hello Paul,
A real nice job, looks very good 8) 8) 8)
Best regards Yves
