JT´s little son
Forum for discussion relating to the Hetzer (Jagdpanzer 38)
Peter Quambusch
Been liked: 995 times
Re: JT´s little son
Post by Peter Quambusch »
Robert E Morey wrote:
Thu Mar 24, 2022 5:36 pm
Peter,
Hope all is ok with your ticker (heart). Hetzer is looking great!
Hi Bob,
Thanks for your concern. All went well so far. Had my second surgery on Tuesday. Got to take some blod thinner for the next 18 months...
But that won´t keep me from building... :D
Peter
Oliver Brüninghaus
Has liked: 551 times
Been liked: 409 times
Re: JT´s little son
Post by Oliver Brüninghaus »
I wish you a good healing so that the build is even more fun.
Best wishes
Oliver
It's Grim Up North
Peter Quambusch
Re: JT´s little son
Work goes on...
... some more dry fitting.
And the final fitting test...
Perfect!! :D :D :D
Pocket Tank!!
Peter Quambusch
Re: JT´s little son
Finally, after the "interior" arrived, work resumed...
...start your engines! :D
Peter Quambusch
Re: JT´s little son
Continued with mounting the gun assembly...
While waiting for the battery to arrive, I started to connect the cables and modules...
... and applied a first layer of dunkelgelb...
Now back to waiting for the battery...
florian rudolf
Has liked: 294 times
Been liked: 640 times
Re: JT´s little son
Post by florian rudolf »
I think its finish for Militracks Peter ;)
Peter Quambusch
Re: JT´s little son
As there is plenty of room, I installed the Famo battery for test purposes...
Battery sits beneath the speakers.
In a couple of days we´ll be heading to the testing grounds...
DaveMacri
Has liked: 13 times
Been liked: 118 times
Re: JT´s little son
Post by DaveMacri »
Curious to hear if you get distortion in the sound with Speakers so close to the engine deck roof, I found that on another build and had to get smaller speakers then install lower in the tank with clearance above the cones.
Peter Quambusch
Re: JT´s little son
Hi Dave,
That´s a good question... But as mentioned, the Famo battery is only for testing. The ordered Hetzer battery will be smaller, thus the speakers will sitt lower. So I don´t think this will be an issue. But will let you know.
Peter
Peter Quambusch
Re: JT´s little son
First track mounted...
Peter Quambusch
Re: JT´s little son
After successfully conducting motor and electronics components tests....
I decided it´s time for some driving on hard ground....
First tests satisfactory....
Now back on the work bench for some more tlc... :D
Peter Quambusch
Re: JT´s little son
While still waiting for the propper battery, JT and son made a quick trip to DK...
At first a little shy, thus under daddy´s supervision...
He soon found a new friend...
In the end, he got many more...
Marco Peter
Has liked: 1422 times
Been liked: 786 times
Re: JT´s little son
Post by Marco Peter »
I really like your camo!
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Peter Quambusch
Re: JT´s little son
Thanks Marco. :D
While still waiting for the battery, started to add some markings
During preparation for Holland next week, had time for a size comparison
Safely parked for the time being
