Mr Dawe's Centurion.
- Has liked: 2259 times
- Been liked: 7149 times
Re: Mr Dawe's Centurion.
Nope, it's still logging me out I just cross my fingers as I write and post the days events. To be fair it was not quite as bad this evening.
- Here's an interesting Australian Centurion photo.
- 36263-be4b1c5a9dc654a289bcc0d7748eba34.jpg (23.58 KiB) Viewed 5245 times
The idlers are just about done all but for some 1.5mm bolts for the hub covers.
I'm still having problems with being logged out!
- Could anyone tell us when these numbers were used, I've only seen this one vehicle with the road wheel hub covers like this?
- R (4)_kindlephoto-476358.jpg (34.52 KiB) Viewed 5193 times
- 9299023576_ba2e1ef5f3_c_kindlephoto-592022.jpg (82.66 KiB) Viewed 5193 times
- Been liked: 1632 times
- Has liked: 1023 times
- Been liked: 2093 times
'Could anyone tell us when these numbers were used
Part numbers, relating to the Ilustrated Parts List and te manufacturer’s drawings. Some also indicate the foundry which cast the part. In this case, ROF W is Royal Ordnance Factory Woolwich.
They’re all over Centurion if you look hard enough.
As my question and road wheel photo suggests I was referring to the road wheel hub covers.
Thank you Stephen, maybe I shall add these road wheel hub id's to the odd one of two on each side unless the later mks didn't use them.
This afternoons exploits.I'm still having trouble with getting locked out.
Stephen, I think Phil was asking could these hubs with part numbers cast in appear randomly on any Mark of Cent or was it particular to early or late marks.
Ah, you’re a mind reader.
The use of casting marks appears to vary between foundries. Supplies of parts to the production line would mix sources. The result is what appears to be random presence on completed vehicles. Parts might be further mixed during base overhaul/upgrading. So they would not be incorrect on any mark.
The second machining stage of the suspension units is now complete.
I'm having trouble loading the days work but will keep trying.
I am having to load photos on my new device, that device has a wonderful up to date camera, then edit and load the text for each photo on my old identical device or I get logged out...very strange.
Testing, I've deleted all cookies, turned off my older device and checked the security settings but to no avail. I'm still getting logged out! It's just hit and miss. I had no problem before the site crashed. If I continuously have to log in even after clicking on " keep me logged in" is the problem my end?
- R (5).jpeg (66.12 KiB) Viewed 4769 times
- Has liked: 597 times
- Been liked: 142 times
Phil - thanks for persevering with your posts through the technical difficulties you are experiencing. I know I speak for others - your work is exceptional to watch, and it would be a real loss to the forum if you couldn’t/didn’t continue.
Kevin
Kevin
