RT Late Tiger One
- Has liked: 1131 times
- Been liked: 990 times
Re: RT Late Tiger One
Got this today.
One crew member and one gorgeous convoy light.
Big thanks to Mark Lawsson.
- Chang
- Has liked: 16585 times
- Been liked: 487 times
Hi Robert,
You late Tiger 1 is stunning in detail.
I am building a 2007 late Tiger 1. The kit does not include the antenna storage tube and mounts. I am try adding that myself. From your June 2021 photo (See attached). I wonder how did you install the 2 tube mounts, and how to lock the storage tube on the mounts? I'll be much appreciated if you can share the assembly drawing figure to show how.
Lerh Chang
Lerh Chang
Hello Chang
Thanks for the nice words, I am only starting to learn this trade.
Here is some pics from that process, and I use silver solder.
I am Happy that you appreciated this.
Robert.
Robert.
- Chang
Hello Robert,
Thank you for the quick answer and many detailed photos. That helps me a lot.
One last question : I estimate the tube's length is about 35cm. Is it correct?
Lerh Chang
Lerh Chang
Hello again Chang.
No problems with your questions, happy to help.
My tube is 360mm, but I am not sure that it is correct. I only had photos to look at.
Have a great building day and stay safe.
Robert
Robert
Had a great day at our woodland course today.
Did some test with my main canon in my Tiger also.
Here is a small youtube you can look at.
Turn up the volyme.
Have a nice weekend.
Robert
Turn up the volyme.
Robert
Hello again.
I have discovered that the side skirts on my late Tiger One, are from a early Tiger.
So I have made a drawing on the new side skirts mounts will be.
So now that template is going to be made in my mill, so I can make some new holes in my Tiger side.
And make new side skirts in Brass.
The measurements are in mm.
Happy working to you all.
Robert
If any want the pdf send me a mess.
Robert
- AlastairCooke
- Has liked: 16 times
- Been liked: 776 times
Hi Robert,
Really like the gun smoke. It is possible for you to share details of how you engineered it?
Alastair
Alastair
Alastair
- Has liked: 481 times
- Been liked: 408 times
Hi Robert
You´r work on the Tiger is really great , you´r eye for correct detail and measurement are great
Just love it
Just love it
Kind regards from Björn
Hello AlastairAlastairCooke wrote: ↑Mon Nov 01, 2021 10:52 amHi Robert,
Alastair
Here you have some pic of how I did it.
The insert is made of steel.
I use an empty cartridge of suitable caliber, and I triggers the charge (Blackpowder) with 5volts.
I found some thing online, look for electric fireworks.
Have a nice day.
Robert
- Has liked: 380 times
- Been liked: 261 times
Hi Robert.
Great build, and amazing work so far.
May i ask you a question on your roadwheels?
What size of nuts/bolts did you use on the inner and outer bolt circles?
TIA
Søren
TIA
Søren
- Has liked: 163 times
- Been liked: 849 times
That is amazing realistic firing sequence. I love all the brass details you've added. One fantastic Tiger!
