Sherman M4A3E8 76(w) HVSS Prototype
- Tim Page
- Has liked: 40 times
- Been liked: 471 times
Re: Sherman M4A3E8 76(w) HVSS Prototype
Hi all, Could the front and rear lights be turned on and off by the Benedini.
The TBS Mini has this functionality built in and as such i dont think would require an extra RC channel.
I am playing with these settings at the moment for my Panzer 3.
- Has liked: 28 times
- Been liked: 2 times
Oh good! More options to buy.
Twist my arm. Ow! Ow! That’s enough! Alright already, you talked me into it!
- Has liked: 1038 times
Umm.... Knowledge Base anyone? The X9D is a great radio for our models but the scope for screwing up OpenTx is considerable unless there's some simple guidance.Armortek wrote: ↑Fri Mar 05, 2021 10:48 am
Our recommended radio of choice going forwards will be the Taranis x9d plus 2019
https://www.frsky-rc.com/product/taranis-x9d-plus-2019/
- Been liked: 3698 times
Some progress on the Sherman prototype. Parts are all coming together nicely - some have veeeery long run times on the machines.
- Sherman z5.jpg (98.26 KiB) Viewed 6632 times
- Sherman z4.jpg (77.93 KiB) Viewed 6632 times
- Sherman z3.jpg (77.02 KiB) Viewed 6632 times
- Sherman z2.jpg (73.76 KiB) Viewed 6632 times
- Sherman z1.jpg (111.04 KiB) Viewed 6632 times
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1116 times
I've been experimenting, bench testing with my older Taranis (pre-2019) x9d to control the guts of my M3 Lee.Stephen White wrote: ↑Mon Mar 08, 2021 11:29 amUmm.... Knowledge Base anyone? The X9D is a great radio for our models but the scope for screwing up OpenTx is considerable unless there's some simple guidance.Armortek wrote: ↑Fri Mar 05, 2021 10:48 am
I'm using:
-2018 Taranis Plus x9d Tx ( using OpenTx 2.3)
-external XJT Tx module
-X8R receiver
-24v 24Ah LiFePo
I'm a old Mode 2 Tx user (since my earliest Futaba days in the 70's) setting defaults as AETR with my tank drive controls on the left stick- throttle and steering. I want to use the left stick for forward/ reverse and steering; it's how I've set up every tank I have.
I'm using Open TX Companion on a Win10 desktop to configure the Tx and model profile(s) via USB connection for this testing.
Modules I've attached so far are motion and sound with the focus of my tests being controlling the L/R drive motors and two geared motors
for turret functions. So far all is well mixing Rudder and throttle except some odd performance near neutral for main drive controls- one motor
insists on continuing running ever so slowly. I think I may have to implement some sort of compensating offset on the output definition or some sort of curve. Still fiddling with that. Other controls seem normal including fail safe settings (set to zero for channels 1-16)- I tested it by shutting down the transmitter with the receiver and modules still powered up and all motors came to a stop ( except for the rogue creeping mentioned above!).
I think that's about it. If someone has a profile they like that works well I'd appreciate comparing notes regarding your settings. If anyone wants a copy of mine I'm sure I could send a zipped backup of my definition as it is so far.
Jerry, great stuff. In order not to hijack this Sherman thread, I’ve copied your post to a new OpenTx thread in the Knowledge Base:
viewtopic.php?f=33&t=8585
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Very impressive model! I really love the volute spring bogies, they look absolutely amazing
Kind regards,
Roy
Roy
A few more prototype photos to see us into the weekend.
- Sherman a15.jpg (84.66 KiB) Viewed 6285 times
- Sherman a14.jpg (84.71 KiB) Viewed 6285 times
- Sherman a11.jpg (102.48 KiB) Viewed 6285 times
- Sherman a10.jpg (92.91 KiB) Viewed 6285 times
Talk about the quintessential torture master. You do know how to churn the anticipation.
I must agree. Not only was the HVSS a great improvement, I think it’s visually more pleasing to the eye.Roy Beukeveld wrote: ↑Sun Mar 21, 2021 10:51 amVery impressive model! I really love the volute spring bogies, they look absolutely amazing![]()
Some more pictures of the prototype. We ill swap out the hex heads on the light guards to button heads to make them a bit more subtle.
Tank looks so much better with the tracks on - although the tracks are not on right as the sprocket is loose and some of the rubber tyres are not on the model.
Shipping is currently looking like it will be end of May/ Early June. We are very much in the hands of suppliers at this stage - all of the machining that we can do will be finished next week - we then need to sit pretty and wait for the tracks, castings and tyres ... and the driven gear which is now 8 weeks overdue
Still - that will give us plenty of time to test out the new elevation mechanism for this model.
- Tim Page
That is really coming together nicely.
It is a shame that the headlight guards have to be bolted in place when they were welded on the original tanks.
Could you not have the legs locating into holes and then epoxy in place.
This would look a lot more realistic and would still be secure.
So far everything else looks spot on and really well detailed.
A very good precision welder could possibly accomplish this.Tim Page wrote: ↑Thu Apr 08, 2021 11:34 amThat is really coming together nicely.
Never mind. It appears to me that the light guards are steel.William Vallejo wrote: ↑Thu Apr 08, 2021 11:59 amA very good precision welder could possibly accomplish this.Tim Page wrote: ↑Thu Apr 08, 2021 11:34 amThat is really coming together nicely.
- Jerry Carducci
Having the Easy Eight is going to be sooo cool...
