Panzer III Elevation Limit switches
LesBernell
Been liked: 34 times
Post by LesBernell »
I'm working on installing the Elevation Components for my Panzer III.
I don't see anything that limits the upward and downward movement of the Barrel.
When the leadscrew Nut hits the end of travel, it bottoms out on the Elevation Slide.
Doesn't this stress the motor?
Has liked: 781 times
Been liked: 1745 times
Re: Panzer III Elevation Limit switches
I had the same question when I was doing my 2017 Tiger 1 and did not see the usual limit switches in the elevation wiring loom. Have a look here bottom of the page:
viewtopic.php?f=6&t=6937&p=66171&hilit= ... tor#p66171
With the new red electronic boxes this thermistor could still be visible in the wiring loom or have been incorporated as part of the elevation output and so not visible in the wiring loom.
LesBernell
Vince Cutajar wrote:
Fri Mar 19, 2021 3:58 am
Thank you. I appreciate the response. I was afraid to try it without knowing how the motor is protected.
LesBernell
I tested the Barrel Elevation today.
It works perfectly.
When the leadscrew hits the end of travel it automagically stops.
I was also worried how the throttle stick would act because it's usually one direction: forward for faster, pull back for slower.
When put in the center, the stick functioned: forward for barrel up, and pull back and the motor reverses for barrel down.
I'm impressed with the technology that Armortek has incorporated into the model.
Mark Heaps
Has liked: 270 times
Been liked: 325 times
Post by Mark Heaps »
With working in the electronics industry, it does not look like a PTC or NTC but rather a poly-switch. An electronic self-resetting circuit-breaker, it will "trip" when the current is exceeded but reset and allow current to flow again once the fault condition is removed.
A PTC or NTC is used on a sensor line to determine temperature and the microcontroller according to its programming will determine what results.
Either in a supply line makes no sense whatsovever.
Has liked: 1448 times
Been liked: 1619 times
