Has liked: 2267 times
Been liked: 7152 times
Working out the vehicle stencils for the large unit id numbers, not as straightforward as you would think!
I've also been doing some more research on 331 and have found some very interesting photos showing the spare track stowage at the front.
Update on the parts I've ordered, the steel tracks are still awaiting a flight out of Oz, the idlers the same and the engine is on its way for Italy. 8) oh and stab antennas and bases from Mark.
Tiger_I_number_331_sPzAbt._503_3 (1)_kindlephoto-1862240.jpg (46.09 KiB) Viewed 3549 times
I can't quite see the brackets that hold the spare track, some units used welded flat stock in pairs some units simply wired them to the hull.
Stencils all done in black with hand painted white surrounds.
This guy just gets everywhere.
Has liked: 725 times
Been liked: 332 times
Post by Christoffer Ahlfors »
I believe that last picture is from the so called "Türkenübung" (Turkish exercise), when the Germans tried to make such a good impression on neutral Turkey as to make it join the war on their side, cutting off the Allies from Palestine and north Africa. Very convincing!
Five stars! :D
But they had a different backdrop in the movie...
More details added to 331 8)
I would like to add the field modification of the basket that was attached to the left rear of the turret stowage bin , if anyone has any information regarding this I would be very grateful, over to you Kent?
You just know what's going to happen to the rifling insert when the the blank firing device does it's thing!
Is 13 the correct wading sequence number for the commanders hatch?
It's a look I've always admired, the glasis up armour.
Often overlooked piece, the optics eyebrow.
I've been dressing the Tiger1 just the way the unit had it, well over a period of say 6 to 10 months, and a lot can change over that amount of time in combat.
That iconic profile is coming together, although she's not sat on the suspension just yet so she will sit lower, more squat and more aggressive.  I shall wait for the steel tracks to arrived before that happens.
mark j. radick
Has liked: 393 times
Been liked: 538 times
Post by mark j. radick »
Looks awesome ! great job !
Liam Mahoney
Been liked: 299 times
Post by Liam Mahoney »
Hi Phil
I have a question, the tanks in the group of photos retrieving 332 from the bog of which your 331 is part of, and the photos of them parked in the orchid give the impression that they are grey?
I acquired a 332 assembled from Alaska and it was painted in the grey, I have also seen other colourised photos from the group in the sand colour, so which is the right colour?
Liam
Good question Liam, I think from many hours of research that the general colour combination was a yellow green with a green camo tiger pattern over. It's a bit like tiger 131, remember all the controversy over that colour combination decision!
Now I could go darker with 331's green but I want to keep it very subtle. I've done very little shading and no washing as yet as that will evolve over time when I can just sit and look at it.
Try editing in your photo library and have a play. 8)
Simon Peck
Has liked: 7 times
Been liked: 46 times
Post by Simon Peck »
This might be of interest....
http://tiger1.info/EN/Grey-Tigers.html
The idlers arrived from Liam today. 8)
Superb craftsmanship, the metal 3d printing "rings like a bell"! You could not distinguish the item from cast ali.
Locking tabs to add when I'm happy with everything.
Has liked: 775 times
Been liked: 1740 times
Idlers look impressive. Are those representing the large (700mm) idlers?
Yes Vince and the quality is amazing, it takes 3d printing to yet another level. They have to be machined with conventional tooling to finish. I can see Armortek using this medium in the future. 8)
I've fitted the superb idlers from Liam, and don't they look good? The steel tracks, well 60% of them are lost at the Coventry international freight hub. So God knows what's happening there! I'm now ringing them every other day to try and get to the bottom of the problem but I speak to a different office every time I get through, and nobody seems to know what's going on, the term " tossers " springs to mind!
As soon as she's finished I will shoot some video of my favorite Tiger 1. 8)
I can't get over just how groundbreaking the metal 3d printing is!
I'm back one the early tiger 1. An update on the steel tracks, Liam is now waiting for one of the boxes he sent to me last year to arrive back at his after a complete cock up with a tracking number miss labelling at our Coventry import hub. This lead to the package being sent all the way back to oz! These things are sent to try us.
Making a start on ivano's superb Maybach.
Ivano sent me some of his beautiful parts to review, so that's what I shall do.
The hl230 goes together. 8)
Ivano's Maybach goes together quite easily.
The air cleaner parts awaiting fitting.
If you have a lathe this job is a whole lot easier but a file will do.
Finding the center of the air cleaners while they are in the lathe.
Carburetors go in.
Carburetors go in.
I love ivano's air cleaner latches.
Carburetor linkages made and fitted.
Checking the fit after cutting the engine in half!
Good news, Liam has posted the package again which contains the rest of the steel tracks, I do feel for you mate, it's hard enough making a few bucks from our hobby without crap from incompetent carrier companies, most are very good but it only takes one!
Anyways some more work done to 331's engine and engine bay. 8)
Exploration20@outlook.com
As the whole unit is modular it can be pulled out and worked on in relative comfort.
Lining up the fan gearboxes.
The electrical regulators and connection boxes ready to go in.
Lots more to add like the wiring.
Good to see those fan gearboxes in place. Did you re-scale them?
