The Sonderanhanger 115 10 ton trailer.
- Has liked: 2267 times
- Been liked: 7152 times
Re: The Sonderanhanger 115 10 ton trailer.
As it's quiet some more progress on the 115
Exploration20@outlook.com
Last edited by Phil Woollard on Mon Jan 11, 2021 8:15 pm, edited 3 times in total.
- Been liked: 1644 times
Looking very good Phil, an impressive vehicle, it's Taking shape nicely, regards simon.
Thanks Simon I just need your half track to pull it!
- Has liked: 4 times
- Been liked: 15 times
Hi Phil
Can you please tell me what you are using for the center front to back planks?
I am planning to make a model of a Ransome and Marles Thresher (circa 1926) which is clad in planks.
Thank you
Graham
Thank you
Graham
Graham
Hi graham, it's 6mm hardwood marine ply which gives great strength and stability. Try to buy marine ply as the glue for obvious reasons is not affected by moisture.
Don't be tempted to use individual hardwood planks as you will have a hell of a job keeping it all in place.
I'm old enough to have worked on a farm that used the ransoms thresher machine although I was very young at the time
- Has liked: 725 times
- Been liked: 332 times
What a dream, to see the two together!
- Has liked: 294 times
- Been liked: 640 times
It's realy a great build Phil,
would like to see it real...
Maybe on Militracks?
Lots done with the "special trailer 115"
- Has liked: 598 times
- Been liked: 145 times
Phil, this is an outstanding build and it’s a real treat to watch the trailer developing.
Keep it up
Kevin
Keep it up
Kevin
Hi Phil
Ref your planking, I have studied the joints and they look like they are burnt in. How did you do that?
They look very realistic.
Graham
Graham
Graham
Graham all I'm going to say is, mark out the planks and the simulated fixings being as accurate as you can, any discrepancy will look pants and you will lose the illusion. Use a stylus following the grain where possible, fill the depression with your chosen medium and clean up.
Phil.
Phil.
You are a master craftsman and as one model engineer to another I take my hat off to you.
Graham
Graham
Graham
Cheers Graham you are a gent.
- Has liked: 26 times
- Been liked: 103 times
G'day Phil,
I follow all your great builds. You get through them so quick. Any thoughts to do àn elefant?
Ray
Ray
