- Has liked: 6 times
- Been liked: 194 times
Hi Phil,
Wow you have one hec of a Tiger 1 there, ur eyes and skills to get the details correct are amazing me like.
Just one thing....those flaps are not flappers in constant use as they are check valves only in use during (Tauch) submerging.
Normaly they was pinned down in open position.
http://tiger1.info/EN/Dragon-mufflers.html
But they do look good in the You Tube clip.
Keep the saga comming the Tiger will be awesome.
It´s all in the details!
- Has liked: 2267 times
- Been liked: 7152 times
Praise indeed from the master, thank you Kent! I'm working on the track pulling rope right now and thats challenging.
Now this Tiger will be for sale at some point but will be for the connoisseur, sold with or without the frightening 12 gauge blank firing device, also with the steel tracks or the standard variety.....so many choices!
Px always welcome.
Px always welcome.
- Has liked: 130 times
- Been liked: 779 times
Phil, the smoke and sound look phenomenal (er would that be Philnominal - ) - Great work indeed. The smoke puffing and chugging is really realistic. I like the flapper valve function as well.
Thanks Bob, got that track pulling rope finished, two days work on that!
- IMG_20201121_165059_kindlephoto-10121878.jpg (108.54 KiB) Viewed 2396 times
- Has liked: 54 times
- Been liked: 689 times
Hello Phil
Outstsanding your model and the pictures. Sometimes is the question: Real or model.
Frank
Frank
Thank you Frank that's much appreciated. When it's finished I hope that in the right light and setting it will look just like the real thing!
I've started on the turret.
Been busy with the mantlet, recoil tube and the fixings.
Turret duties.
Friday fetling.
Lots done today I may fit the weld detail tomorrow but really I should have a day away from the workshop.
- Has liked: 725 times
- Been liked: 332 times
"Just about done but for the tiny holes on the vertical face equally spaced all the way round, don't know what they are for?"
They are drainage holes. Without them, the cupola would hold quite a bit of water, covering the hatch, providing a very unpleasant surprise when opening...
I should soon be on to the gun at this rate!
The loaders hatch.
Phil,
Fantastic details to the gunners hatch and cupola.
